What order do I bleed and replace brake hoses?
- BlackBart
- Has thanked: 967 times
- Been thanked: 923 times
He’s replacing hoses, so the system is open.MoVolvos wrote: 27 Mar 2024, 02:23Air is only at the end of the line if the system is not soft. Don't want to bleed all at once and discover after the 4th it's still soft. Have to redo all again not knowing which one is the culprit.02V70 wrote: 26 Mar 2024, 16:14 I assume you meant brake hoses. Don't I need to bleed immediately after replacing to get the hose filled with fluid?
02V70 - you’re essentially flushing the system with new fluid and then bleeding air bubbles out after all lines are filled.
I didn’t know about the front wheels first bleed order - is this because of ABS piping?
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
.BlackBart wrote: 27 Mar 2024, 21:26He’s replacing hoses, so the system is open.MoVolvos wrote: 27 Mar 2024, 02:23Air is only at the end of the line if the system is not soft. Don't want to bleed all at once and discover after the 4th it's still soft. Have to redo all again not knowing which one is the culprit.02V70 wrote: 26 Mar 2024, 16:14 I assume you meant brake hoses. Don't I need to bleed immediately after replacing to get the hose filled with fluid?
I replaced all the 03 S80 T6 hoses with a set of FCP stainless a few years back. The fluid just gravity flow so no air except at the end. I flushed till the fluid was clear and pedal firm then continued.
If I replaced all the lines and after bleeding the last found it was soft, I wouldn’t know which line needs more work. This is why you need to establish a baseline.
If you start with a spongy pedal you would bleed all four. Assuming after bleeding the first line and the system is soft, you either bleed more or go to the next if you don’t see any bubbles. Hopefully in between or by the last line the system is purge and pedal firm.
I did the short line first or reverse bleeding not too long ago. Didn’t want to mention it as it is not what everyone is use to. Can see why it wouldn’t make a difference as each individual brake line starts close to the reservoir.
- 02V70
- Year and Model: 2002 V70XC
- Has thanked: 53 times
- Been thanked: 40 times
When you say soft, that means there is air in the system, right? When pressing the pedal to see if it is spongy, I do not need to start the engine, correct?
2002 v70 X/C 288k miles
- MoVolvos
.02V70 wrote: 27 Mar 2024, 22:24 When you say soft, that means there is air in the system, right? When pressing the pedal to see if it is spongy, I do not need to start the engine, correct?
Yes, start the engine to determine where your system is at. If it's spongy you could go ahead and bleed the system till it's firm. This way you know which line had air. Once you start you might as well bleed all the other lines so there is fresh fluid in the entire system. Make sure to bleed until new fluid is coming out regardless whether if the air comes out right away. After you replace each brake line you only have to bleed the new (last) section of air so pretty quick as the system already has new fluid through out.
If the system is firm after testing you can go ahead and replace the line but be sure to bleed till new fluid comes out. You are not only purging air but flushing that entire section of dirty fluid. Only when the brake is firm with new fluid coming out do you proceed to the next brake line replacement.
Doing this ensures you know your work is done well before preceding.
- Has thanked: 1611 times
- Been thanked: 4075 times
Each time I have a caliper open I replace any older bleed valve with a FreeCP one, the push 257 ml of brake fluid through to get fresh stuff in. 4x 250 ml is one liter, which also goes back to FCP
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
For the spongy brake pedal you need to actuate ABS. Chances are the air bubble is not in ABS, but frankly I don't remember I ever heard of air in P2 brake system that was not in ABS.
You need DiCE or Mongoose JLR cable (that is: Jaguar Land Rover - it has 2 CAN buses as well), and VIDA, of course.
- Has thanked: 987 times
- Been thanked: 1078 times
When FCP stops return for credit for you, we will know the limit of their generosity.abscate wrote: 28 Mar 2024, 04:17 Each time I have a caliper open I replace any older bleed valve with a FreeCP one, the push 257 ml of brake fluid through to get fresh stuff in. 4x 250 ml is one liter, which also goes back to FCP
- 02V70
Why would there be air in my abs system? I am flushing the brakes because I am replacing the brake hoses and might as well flush the old brake fluid at the same time. The pedal was never spongy. Removing the brake hoses and bleeding the brakes should not introduce air into the abs system, right?
- MoVolvos
.02V70 wrote: 28 Mar 2024, 11:32 Why would there be air in my abs system? I am flushing the brakes because I am replacing the brake hoses and might as well flush the old brake fluid at the same time. The pedal was never spongy. Removing the brake hoses and bleeding the brakes should not introduce air into the abs system, right?
Yes, your baseline is system without air so you're good to go with the line replacement. Just bleed entire line till you see clean fluid before continuing to the next.
- 26 Replies
- 13774 Views
Last post by cn90
- 1624 Views
Last post by moonweasel
- 2794 Views
- 304 Views
Last post by cn90
- 43 Replies
- 9944 Views
