What order do I bleed and replace brake hoses?
02V70
Year and Model: 2002 V70XC
Has thanked: 53 times
Been thanked: 40 times
Post by 02V70 »
I am replacing the brake hoses, and bleeding the fluid at the same time. Would the order to bleed and replace hoses be this?
(directions are supposing you are in the driver seat looking forward)
Right Rear: Replace Hose
Right Rear: Bleed
Left Rear: Replace
Left Rear: Bleed
Front Right: Replace
Front Right: Bleed
Front Left: Replace
Front Left: Bleed
Is there anything different I need to do since it has ABS?
2002 v70 X/C 288k miles
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
How to Bleed Your Brakes - FCP
https://blog.fcpeuro.com/how-to-bleed-your-brakes
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
I'd replace the brake pads first, then bleed later.
02V70
Post by 02V70 »
I assume you meant brake hoses. Don't I need to bleed immediately after replacing to get the hose filled with fluid?
BlackBart
Has thanked: 967 times
Been thanked: 921 times
Post by BlackBart »
Yes.
I think it’s more efficient and less wasteful of fluid to replace all, bleed once. One at a time, you’re chasing bubbles in lines all over the place.
MoVolvos
Post by MoVolvos »
02V70 wrote: 26 Mar 2024, 16:14 I assume you meant brake hoses. Don't I need to bleed immediately after replacing to get the hose filled with fluid?
If the system is soft bleed first. If not bleed after each side. You need a baseline to start or else you won't know till after bleeding all four.
Air is only at the end of the line if the system is not soft. Don't want to bleed all at once and discover after the 4th it's still soft. Have to redo all again not knowing which one is the culprit.
P80GLT
Has thanked: 154 times
Been thanked: 176 times
Post by P80GLT »
Vida says LF, RF, LR, RR with the pressure bleeder, but it makes no difference in practice . The only problem can be if you do it mechanically by pressing the brake pedal right down to pump the fluid through and any corrosion in the master cylinder damages the seal on the piston as it travels down to areas it has never reached before.
1997 850 GLT website
2010 XC90 SE...SOLD
2005 V70 2.5T SE
vtl
Year and Model: 2005 XC70
Has thanked: 129 times
Been thanked: 686 times
Post by vtl »
I haven't noticed any difference.
Don't forget to remove the caliper and spread the pads to have all of the old fluid out of calipers. Vacuum brake bleeder works best in my opinion. You may also want to trigger inlet/outlet valves of that corner in VIDA to evacuate possible air bubbles trapped in ABS.
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
I also like the hand pump vacuum bleeder method. Easy, one person process.
02V70
Post by 02V70 »
I do not have vida and I am using a vacuum bleeder from harbor freight. Would I use the order I put or the opposite one that vida recommends for pressure bleeding?
