98 S70 upper radiator hose
- foggydogg
- Has thanked: 83 times
- Been thanked: 405 times
Advertising pseudo-scientific horsemanure. The suggestion on here is to avoid URO anything. The blue box Volvo cap will have the pressure molded into it, expressed in metric-speak as 1.5 bar or some such. In plain 'Murican it's a 22 pound cap. They don't fail often, so the cost of the factory part is likely a one time expense, and worth it for the peace of mind.mar601 wrote: 21 Apr 2024, 09:18 All it says on that URO cap is that it's "factory pressure tested". ?
As mentioned earlier, there may be another issue, but try really cleaning the radiator port and if the original clamp is still serviceable use it instead of an inexpensive parts store one.
- Clemens
- Has thanked: 500 times
- Been thanked: 228 times
Also, use a high quality hose clamp, not a Chinese knock off.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
mar601
- Year and Model: 1998
- Has thanked: 34 times
- Been thanked: 5 times
Ok thanks. I put on the new hose and so far so good -- put on the URO cap "for now". When it blew off I was on the road so I think it may have blown off again because I didn't clean off the coolant and it was a slippery connection. ? The old hose was in bad shape.
- 3649 Views
Last post by t3yf5g
- 810 Views
- 28 Replies
- 1571 Views
- 12 Replies
- 5693 Views
Last post by difflock54
- 11 Replies
- 2545 Views
Last post by bob850
