Exhaust leak? Mistimed? Lifter tick?
jsrnsis
Year and Model: P80 enjoyer
Has thanked: 25 times
Been thanked: 71 times
Post by jsrnsis »
scot850 wrote: 10 Sep 2024, 10:36 They can store a lot of condensation in the systems and it can take a good long run to blow it all out.
Not that I like huffing exhaust gasses or have a tuned nose, but it never like burning oil or sweet like coolant mist from a heater core, but I don't know if coolant that's been through combustion would smell any different.
As for the exhaust leaks, I assume my option is just to take everything apart and apply some high-temp sealant or exhaust putty to the surfaces?
The wastegate pivot has a lot of play in it when fiddled with but seems similar to the other turbo I have access to. Not sure if there should be a seal here, but it seems odd that there's an evident exhaust leak.
1998 V70XC black 215xxx
2014 S80 T6 AWD 110xxx
1998 V70XC nautic blue 155xxx
2024 Honda CRF110F
Previous Volvos:
1997 850 GLT 239,577
1998 V70 NA silver 202,510
1994 850 NA gray 125,000
1998 V70 NA white 163xxx
1997 850 GLT 125xxx
Has thanked: 2215 times
Been thanked: 1853 times
Can't answer the turbo question.
The mufflers tend to cause a lot of condensation to form in them when cooling. Short journeys also aggravate the build up. It is not leaking coolant or oil.
I have to shortly get under my son's XC70 again and remove the back box and reseal is again. It always leaks at the joint where Volvo cut the old pipe off and fitted this part replacement.
