1996 850 GLT Wagon Gas Gauge Never Reads Full
454cid
Year and Model: 1996 850
Has thanked: 151 times
Been thanked: 139 times
Post by 454cid »
NotAnElectronicsGuy wrote: 06 Jun 2024, 16:49 If it is not raining tomorrow, (starting to feel like I need webbed toes/fingers, and gills),
We had rain in MI for a few days, but now it's just really windy. It's holding up my spray painting!
I will pull the air filter box and see if the flapper between the hot air and cold air intake is FUBAR.
I replaced the Air Mass unit maybe 5 years back, and it seems like that is working O.K.
Isn't the GLT a low pressure turbo? ... or was that only on the later cars like my 99 S70? If you have a turbo, you won't have the flapper. I got rid of the flapper on my naturally aspirated 850 by switching to a lower air box from a turbo car.
The flapper in my 96 850 would hang out between both positions, and didn't affect starting at all.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
NotAnElectronicsGuy
Year and Model: 1996 850 GLT Wagon
Has thanked: 1 time
Post by NotAnElectronicsGuy »
Here is an oddity... and thinking/hoping this *could" have been the problem all along. If I do not need to crawl into the gas tank- so to speak- or mess around with wires, floats, and etc., I will be very happy.
So, my rear springs were crapped out, badly, and the car was very low in the back, like 3,5" or so. Low enough that I bumped my head on the hatch.door when it was open, and I am only 5' 5"!
Got new heavy duty springs with thode rubber bushing on the top installed, and the rear end is noticeably higher. I will go fill up tomorrow [Monday] , and see where the gas gauge goes to.
Will let y'all know!
NotAnElectronicsGuy
Has thanked: 1 time
BEJinFbk wrote: 06 Jun 2024, 17:24 Just for grins, where is your voltage level
hanging out when the car is running.
I’ve never heard of low system voltage
causing that particular problem, but
it’s always a good thing to consider
with electrical problems.
Voltage output from alternator checks proper level, (and a new battery, too).
NotAnElectronicsGuy
Has thanked: 1 time
Well, the replacement springs getting the back of the Volvo to where it should be did change the position of the gas gauge needle a little bit.
When we were done replacing them, the needle went to 12 gallons. When I filled the tank it took 6.3 gallons, and the needle still read what I am guessing would be about 2.5~3 gallons below the 18 gallon level.
This means the gauge is correct at 12, low at full, (sticking there, maybe?), and when it goes down again on a highway driving trip this weekend, we will see what it looks like when I re-fill it on return on Monday.
And it looks like I am going to have to crawl into the gas tank, so to speak, and see what I can find there, after all.
