1996 850 Fuel Gauge .2" Below Full When Full
PeteB
Year and Model: 1996 Volvo 850 Wagon
Has thanked: 57 times
Been thanked: 11 times
Post by PeteB »
Fuel Gauge is not going to full, I'll pull the sensor unless there are other suggestions.
Klausc
Year and Model: 1995 855 Turbo
Has thanked: 5 times
Been thanked: 15 times
Post by Klausc »
My older 1994 and current 1995 had the same problem. For the 1994, I took the sender apart (canister type) and cleaned the top portion of the sender. With the 1995, last summer, I took the sender out and just made the internal slide go up and down a half dozen times - it has worked properly ever since.
Klaus
PeteB
Post by PeteB »
Thanks, was hoping for something easy!
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
What could be easier than that?!
About 15-20min job.30 if you want to take it apart and clean it.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
fisker247
Year and Model: 1997 850 T-5
Post by fisker247 »
I have a 1997 850 T-5 (313,245 miles) and am reading 16/18 gallons upon fill up top off.
I would like to go in a replace the fuel pump (last done at 148,325) using Roberty DIY (awesome dude!)
Would I be able to unplug and clean/clear the fuel sensor (no idea where it is or how 2) myself to make sure the range of motion is clear and able to read accurate?
Anyone done this yet? Any better videos?
Many thanks!
