No crank 2 days after 4" puddle
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
Tarquin
Year and Model: 2005 S60
Has thanked: 5 times
Re: No crank 2 days after 4" puddle
Post by Tarquin »
scot850 wrote: 18 Aug 2024, 01:43 Can't recall, but does the 05 have the rear end of the starter mounted on a bracket like the P80's? I don't think so.
The starter can get hung up on the dowel pin. If you can't just work it back and forward to break it loose, you may have to try a pry bar or a flat blade screw driver gently hammered between the flange and the starter near the dowel.
Thanks scot850, I sprayed a little penetrating oil on the pin last night, and this morning I was able to gently tap a putty knife in between the flange and the starter. Eventually managed to pull it out.
There was no bracket on the back of the starter. I can't see one on the starter of my 2001 V70 either. My 98 S70 has been gone so long, I can't remember...
Current:
2005 S60 2.5T AWD
2001 V70 2.4T
RIP: :(
1998 S70 T5 Manual
Has thanked: 1843 times
Been thanked: 1710 times
I didn't think they had them on the P2 but been a while since I pulled a couple of spares for our son's car for the 'just in case pile!'
The bracket most didn't re-use and I think the later P80 cars and P2 have smaller physically starters, so the bracket is overkill.
Good luck! You could try jumper cables to the starter and see if it runs. It may not be totally broke and may just be the solenoid that is bad.
Tarquin
Post by Tarquin »
Pulled the starter out and did a bench test
12V Battery Positive terminal - to- Starter terminal
12V Battery Negative terminal - to- Starter housing
12V lead from Starter terminal - to - the signal post
Basically like this:
Nothing happens. It looks a little rusty inside, so thinking it got wet, and when I let it sit for two days, it seized up. I can rotate the gear manually. It's quite stiff.
I'll swap it out and post the results.
Current:
2005 S60 2.5T AWD
2001 V70 2.4T
RIP: :(
1998 S70 T5 Manual
Year and Model: 2004 V70 2.5T
Been thanked: 468 times
Post by cn90 »
If you go to junk yard, then starter motor design changed after 2006, so 2007+ starter has different number of teeth and connector.
Not sure why Volvo did this change bc it is the same engine anyway...
BlackBart
Has thanked: 927 times
Been thanked: 884 times
Post by BlackBart »
If it is the starter, maybe it was on borrowed time and just happened to quit.
Tarquin
Post by Tarquin »
cn90 wrote: 18 Aug 2024, 12:15 If you go to junk yard, then starter motor design changed after 2006, so 2007+ starter has different number of teeth and connector.
Thank you for that info.
Current:
2005 S60 2.5T AWD
2001 V70 2.4T
RIP: :(
1998 S70 T5 Manual
Tarquin
Post by Tarquin »
I took a closer look on my 2001 V70 and there was a bracket on the back end. Maybe on the 05 it was lost at some point.
Current:
2005 S60 2.5T AWD
2001 V70 2.4T
RIP: :(
1998 S70 T5 Manual
Tarquin
Post by Tarquin »
So I replaced the starter and it started right up. :)
Thanks for all of your help!
Remnants of the broken splash shield were still holding on. I replaced that too.
Current:
2005 S60 2.5T AWD
2001 V70 2.4T
RIP: :(
1998 S70 T5 Manual
jonesg
Has thanked: 69 times
Been thanked: 481 times
Post by jonesg »
BlackBart wrote: 18 Aug 2024, 13:37 If it is the starter, maybe it was on borrowed time and just happened to quit.
probably ...
Well done and thanks for sharing your success!
