98 s70. What is this coolant hose clamp and how do I remove it
- Sveedy
- Has thanked: 445 times
- Been thanked: 479 times
I think that's a cool clamp. Definitely a heavy duty little cuss. Worth keeping.
1999 V70 GLT
1999 V70 GLT
7mm is a 9/32 Imperial I think ??
Use closed banded clamps on this stuff to protect the hoses. They need to be pretty tight so Torx or hex heads are much beefier than slotted screws
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
.coop wrote: 26 Sep 2024, 09:36 Slightly between 1/4” and 9/32. I’ve been having that fun trying to find vaccum lines at the auto parts store since there’s so not many metric options.
As long as it's close and won't collapse with heat you should be fine. To stretch or not to stretch in terms of sizing availability is the question.
- MoVolvos
The grooves indicate some kind of worm gear on band grooves rather than the bolt and nut which is a smooth band.
coop
- Year and Model: 1998 s70 t5
- Has thanked: 17 times
- Been thanked: 15 times
The 5mm or close to 5mm tubing they carry is meant for windshield wiper fluid. It works but it’s a pain in the ass to work with trying to get the turbo vac lines replaced on the engine side. I ordered some silicon tubing but the oem Volvo stuff seems way better for this application and for ease of use.MoVolvos wrote: 26 Sep 2024, 10:22.coop wrote: 26 Sep 2024, 09:36 Slightly between 1/4” and 9/32. I’ve been having that fun trying to find vaccum lines at the auto parts store since there’s so not many metric options.
- 16 Replies
- 6829 Views
Last post by RickHaleParker
- 706 Views
- 915 Views
Last post by polskamafia mjl
- 1564 Views
Last post by simonology101
- 1223 Views
Last post by mrbrian200
