No problem, thanks for your website. It really is a treasure trove of info. This 850 is my real first project. The guys here have been really helpful.
'92 850 2.0 20V Intake Swirl Flap. Missing solenoid, do I lose a lot of power?
- koralski
- Year and Model: '92 850
- Been thanked: 7 times
Are you positive about that?misha wrote: 08 Apr 2025, 11:52You will have the same results as leaving it as it is...because ecu is programmed to have variable intake.koralski wrote: 08 Apr 2025, 11:23 I think we'll just change the intake. The system is complicated and the vacuum lines are gone, as well as the solenoid. I think the solenoid is NLA.
You will need to tune the ecu to run the engine without it.
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Pretty sure.
Without it...ecu will set CEL and disable or disturb the fuel trims.
Does the car have MAF on air filter housing or just IAT sensor like 10v cars?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- misha
Try with a regular intake manifold...you have nothing to loose...it can't be worse.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- koralski
That is true. I will swap them. Is there any scientific test I can do to check if it is better or worse?misha wrote: 08 Apr 2025, 13:57 Try with a regular intake manifold...you have nothing to loose...it can't be worse.
0-100?
- misha
I don't know...i think that variable intake is there to provide more torque in lower rpm.
Not really sure what is it's purpose since all other engine managements don't have it.
Maybe Volvo solved that with different software.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- 203 Replies
- 10511 Views
Last post by volvolugnut
- 1285 Views
Last post by rodiram
- 291 Views
Last post by lrock
- 20 Replies
- 1605 Views
Last post by MoVolvos
- 1404 Views
Last post by SuperHerman
