95 850 NA Burning oil after rebuild
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 445 times
Been thanked: 479 times
Post by Sveedy »
Looking at the valve seals - don't some of these engines have 6mm valve stems instead of 7mm ?
1999 V70 GLT
fredt2
Year and Model: 850 GLT 1995
Has thanked: 2 times
Been thanked: 7 times
Post by fredt2 »
misha wrote: 02 Jun 2025, 09:49 What oil viscosity is in the engine?
Did it burnt oil before rebuilt?
How about valve guides?
Did the ring had out of spec gap when you put it into a sleeve and leveled with a cylinder....before putting it onto a cylinder?
Was pcv system cleaned or replaced during this job?Could be clogged...also flame trap could be clogged.
Currently using 15w40
Sometimes burned after sitting idling or on a traffic jam, or when revved cold
Probably not valve guides, I've rarely seen these fail, and as I didn't mess with the valves when the head was off, I doubt they would suddenly fail like that
Well, I forgot to check for ring gap while I was putting it together, probably screwed up there
And yes, I cleaned the entire PCV system when the head was off, hoses, catch can, oil galleys and so on
Also, just did a compression test, looks normal to me:
Cyl 1 - 180psi
2 - 205psi
3 - 180psi
4 - 185psi
5 - 188psi
Could be fake since the amount of oil getting into the combustion chamber
