I found a used intercooler at a junk yard today and have the radiator, fan and intercooler out of my car...I've cleaned up everything...used brake cleaner in the intercooler to get any oil residue out and flushed the radiator with water from a hose and then distilled water. It'll all go back in tomorrow and hopefully I won't have any more issue with the car...I'm thinking my MAF is fine.
The skid plate from IPD saved my oil pan and engine...also transmission and probably the hard A/C lines and no telling what else:
However it does not extend in the front enough to cover the intercooler lip which is under the plastic "air dam" but the plastic is no protection if you hit something hard enough. If you're ever in a no-start predicament after you go off the road with a turbo car, get the air dam out of the way and take a look, your intercooler could look like mine. The only way to get home (if you're not leaking oil, transmission fluid or coolant) at this point is to unplug the MAF Sensor and limp home. Here's a picture of my cracked intercooler:
