850 '97 roof rack suggestions
- Has thanked: 17 times
- Been thanked: 35 times
Once these load bars are on, they are stationary- they won't move up or down... Whatever you have to tie down, etc., will have to fit over where they are. Hope this helps (the limitations of load bars vs. eurorails).
milesursogood
- Year and Model: 850 T-5, 1997
MJ - i was given a pair of load bars off an 850 sedan. i was trying to put it on my '97 wagon, but couldn't figure how to close the outside door. the lock core is bottoming out on the internal components. i couldn't figure it out how to make it work.MadeInJapan wrote:Yes, it comes ready to fit right on...there are small holes right in the upper door seal area that a pin from these racks fit right into- the rack (or rather load bars) are from Volvo and they are rectangular in shape.
1997 850 T-5 142k miles - Mobil-1
michaelvettel
- Year and Model: 2004
try online automotive stores they have tons of brands that suites all cars of just simply universal to use.
_________________________
Roof Rack and trailers
VolvoTurbo850
- Year and Model: 1994 850 (T5)
i actually have the thin rails listed above on my v70 thin rail.jpg (16.73 KiB) and they work great .. specially when you have to transport a hood!
Don`t forget to order the oem screws from volvo ( 6 of them about 1 buck a piece).
If you want it for bikes i would buy the ones which connect to the hitch of the car and use that. I find them much easier to load up to 3 or more bikes and keeps mud and scratches getting on the roof!
http://www.etrailer.com/dept-pg-Hitch_B ... _Rack.aspx
The Fleet
2001 V70 (NA) 2.5
1999 C70 Conv. Turbo 2.3 HPT
1998 S70 Turbo (T5) SE
1994 850 Turbo (T5)
1980 Corvette (Corvolvo)
Previous Possessions: (4) 240's, (1) 740, (9) 850's, (5) 70 Series
Projects on the go: NONE... Yet!
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
The other dealer item that is very useful for installing "pre-owned" rails is the sealing kit.
It provides all new rubber and trim parts that go between the roof and rails.
You can also buy the screw covers and clips seperately. Makes'em like New!
I just got a factory rack and crossbars from the junkyard for $40. Took all of the trim too including the stuff on the windshield edges. Half hour later I had the entire thing installed on my car. All of the bolt holes were there (under plastic blocks and sealant tape) Took the rack off of a 98 V70XC and put it on my 96 850. Good luck!
- 1164 Views
Last post by packetfire
- 8383 Views
- 2690 Views
Last post by JimBee
- 705 Views
Last post by Jprezguitar
- 705 Views
Last post by hausmeister
