spongy brakes on 2002 S60
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
Has thanked: 17 times
Been thanked: 35 times
Re: spongy brakes on 2002 S60
Post by MadeInJapan »
Replace your brake fluid and bleed your brakes- I would think that it's just old and has absorbed water making the fluid less efficient.
sprag
Year and Model: 2002 S60
Post by sprag »
The car has 60,000 miles on it and was serviced @ the dealer on every intervel.We bleed it four times using a pint of fluid.The orginal fluid looked new and clean.I analyzed fluid that came out on the first bleeding and it is perfect.It is a one owner car that was garaged,very clean.No moisture.
sprag
Post by sprag »
Well you were right I had the springs wrong.Thanks for all your help.I feel like a jerk.Problem solved!!!
vegasjetskier
Year and Model: 2010 Toyota Prius
Been thanked: 6 times
Post by vegasjetskier »
sprag wrote:Well you were right I had the springs wrong.Thanks for all your help.I feel like a jerk.Problem solved!!!
Don't beat yourself up over it. It's an easy mistake to make. Glad you got it fixed.
