spongy brakes on 2002 S60
After I replaced front and rear brake pads on my 2002 S60 with better quailty I have a spongy pedalthat goes to the floor.I did not open bleeders when I replaced pads.I bleed them and still have same problem.
vegasjetskier
- Year and Model: 2010 Toyota Prius
- Been thanked: 6 times
Did you put the springs back in the right place?
vegasjetskier
The anti-rattle springs on the calipers.sprag wrote:Which springs are you referring to.
vegasjetskier
And they were fine before you changed the pads?
vegasjetskier
Then it's quite likely that something is not installed correctly. If it was OK before, it should be OK afterward. I would go back and check over everything to make sure that it's all installed right. See this link for some pictures of what it should look like. https://www.matthewsvolvosite.com/forums ... hp?p=50801sprag wrote:Everything was fine before I replced the pads,even the pads were fine about half worn.
Especially check the springs. Some people who have had the same problem you do didn't put the springs on correctly. When they later installed the springs the right way, the brake pedal came back. Be sure to pry them over the ears on the caliper.
vegasjetskier
This link better shows how to install the springs (the last 3 pics): https://www.matthewsvolvosite.com/forums ... 11&t=17390
The springs are on correct.The pedal gets a little better when I pump it and feels OK with the car not running.
If it was a spring/assemble problem,the pedal wouldn't change when pumping.It seems more like a hydraulic problem.Are these cars known for master cylinder problems.We checked for a vacuune leak @ the booster and it is quiet.
- 3940 Views
Last post by dieudonneMC
- 4742 Views
Last post by oragex
