Just to commiserate, I'm having the same problem with my 1996 850 with 210,000 miles. Pads are down to about 1/4", so I ordered new pads and shims from FCP Groton. Will probably put them on in the next couple of week-ends. I've had the car since 1998 with 25,000 miles. Never had this problem before. When I pulled the pads to inspect them, there were no cut out shims in place.
Some days it does it and some days it is fine.
95 850 - Low 'bass' resonance when braking
1998 S70, 5 speed manual, 146k, wife's car
1997 850 Wagon, 5 speed manual, 185k, son's car
1996 850 5 speed manual, 220k
1985 MB 300D 268k, running on B20 biodiesel
1983 MB 300D 240k , converted to vegetable oil
1981 VW Vanagon 184k
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Glazed over rotors/pads can do it from long braking in hot temperatures. Give em a good, hard stop from a high speed and see if it quits.
'98 S70 T5
2016 Chevy Cruze Premier
xjflexer
- Year and Model: '96 850 R Wagon
Either have your rotors turned (machined) or buy new rear rotors. Sounds like they are warped. When regreasing the shims, you are kind of renewing the "suspension" between the pads and shims, which are just hiding the pulsation and dampening the noise caused by the warped rotor. Once the grease gets squeazed out some to decrease the amount of dampening, you get your noise and possible vibration back.
TIP...if you buy new rear rotors, used soap and water to clean the anti-corrosion film off of the new rotors. Don't use brake klean. Soap and water does a better job of removing this film.
**EDIT** I almost forgot, if you get new rotors but are going to keep your exisiting pads, sand down the pad surface slightly to make it "true" and remove any glazing. This will help your pads seat into the new/freshly machined rotors better.
that was my first guess.vegasjetskier wrote:Warped rotor(s)?
Does the wheel wobble at all? if the wheel wobbles when stopping then the front rotors are a little warped u obviously will not feel it if the back ones are warped but the noise may still be present.
1998 S70 T5 SE 214,001
1999 v70R 126,000
1999 v70R 126,000
meine39
- Year and Model: 1995 850 GLT Wagon
Nope - the car stops straight and true. The car is within a foot or two of being completely stopped before the resonance begins. Nothing is felt through the steering wheel, and the sound seems to originate from the rear.Does the wheel wobble at all? if the wheel wobbles when stopping then the front rotors are a little warped u obviously will not feel it if the back ones are warped but the noise may still be present.
1995 855 GLT 190K NA Auto
1998 BMW 528im 137K
2000 Toyota Camry 78K
2010 GMC Acadia 57K
1998 BMW 528im 137K
2010 GMC Acadia 57K
meine39
Bumping this thread. Time to sell this car and this problem is back - definitely associated to outside temps (hot here right now). Note that original post was in August. Tempted to swap out rear rotors and pads for new, as much as I hate putting the labor and money into a car I'm selling.
1998 BMW 528im 137K
2010 GMC Acadia 57K
1998 BMW 528im 137K
2010 GMC Acadia 57K
- RussB
- Year and Model: '00 S70, '04 S60
- Has thanked: 3 times
Try some aftermarket pads...they me just different enough in materials and construction to avert the vibrations
'00 S70, '04 S60 and the never ending quest for Stage Zero
- Has thanked: 1611 times
- Been thanked: 4075 times
I put on a set of "scored" rear discs that brake really well but have always drummed a bit on the 1999. Are your discs smooth or do they have relief grooves??
meine39
Rotors are stock (smooth faced) Volvo parts. Not a fan of drilled/slotted rotors, but that's a different topic
1998 BMW 528im 137K
2010 GMC Acadia 57K
1998 BMW 528im 137K
2010 GMC Acadia 57K
- 2059 Views
Last post by JRL
- 6431 Views
Last post by romchik007
- 15 Replies
- 2261 Views
- 1641 Views
Last post by IronMike
- 13 Replies
- 5500 Views
Last post by theobviousfaker
