How do I remove the steering U-joint on my 1995 850?
LamboSE5
Year and Model: Empty
Post by LamboSE5 »
Can one of the pros chime in here please? I'm surprised there isn't more interest in the steering components areas, i.e.: rack, u-joints etc.
I'm using a post by MIJ ( I think ) and haynes... to moderate success.. that is I'm stuck.
Vid
I was also going to attempt to remove the rack in case what's causing my poor steering in the other car is its rack. But if I can get these u-joints out I might be satisfied.
Thanks for any help
fazool
Year and Model: S60, 2007
Been thanked: 7 times
Post by fazool »
Imagine a straight cylindrical shaft (like a long rod or pipe). When you rotate it, the whole thing rotates. If you need to "bend" your shaft, you cant rotate it anymore because of the elbow (where it's bent).
So, any place your shaft has to bend, there must be a flexible joint. You can have as many u-joints as your path needs to bend around objects.
On something like a RWD driveshaft, these joints are in place to allow the rear wheels to move up and down on the springs. In that case, two U-joints are used to keep the input end and the output end parallel, but allow them to "float" up/down.
Image from www.4crawler.com, original page and excellent paper on U-joints can be found here :
http://www.4crawler.com/4x4/CheapTricks ... -101.shtml
2007 S60 2.5T AWD (Daily Driver)
2001 S60 2.4T (Daughter's Car)
2003 S80 2.9 (Son's Car)
1995 850 2.4 (Daughter's Car - sold off)
2005 S40 2.4i (Bought new - since sold)
1986 740GLE 2.3(First Volvo - sold off)
alexk243
Year and Model: 1993
Post by alexk243 »
Did you guys buy new flex joints or just grease and clean them? If you bought them then where did you get them?
Thanks
1993 Volvo 850 (w/97' engine in it)
Bucker
Year and Model: 96 850 GLE
Post by Bucker »
MadeInJapan wrote:I don't think so- start at about where the "remove steering shaft boot (gaitor) and needle bearing" section begins in the file below-
850 steering column.pdf
Hey guys,
Im trying to open this PDF file and it says I'm not authorized to view this attachment.
This information would REALLY help me as I've got my car on the hoist right now and am having a bit of trouble.
Any help would be great.
Thanks
Bucker
