760GLE '88 Exterior Bulbs and Moisture
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
DeRail
Year and Model: None
Re: 760GLE '88 Exterior Bulbs and Moisture
Post by DeRail »
I was trying to adjust the two nuts (sorry, not bolts) on the cable behind the rear ash tray. The cable runs through to the other side of a metal partition to where it connects to the handbrake ratcheting system. Well, there is a round piece of metal that sits against the partition and it is quite loose, it only snugs up with 4 or 5 clicks of the brake. So, I was trying to adjust the nut that was closest to the handle on the side with the two adjusting nuts.
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
Right place but possibly something in there has come loose.
The attachment shows what should be there and how it works. It sounds as if the locking sleeve isn't coming back into place after you do the adjustment. If so the thing will unscrew itself.
700 handbrake adjust.pdf
(444.23 KiB) Downloaded 254 times
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
DeRail
Post by DeRail »
Thanks for the Haynes scans :)
I was using mine when I was trying to adjust this thing but it never occurred to me that I never had to push any locking sleeve. In fact, when I took the rear ash tray off, it looked like figure 7.2 there was no sleeve there. Did some vehicles not ship with this sleeve, or is it just plain missing?
Thanks
Darrell
billofdurham
If you look closely at 7.2 you will see that the sleeve is there but the spring has been compressed. All of my books give the same instruction as Haynes, including one which is specifically for the US models. Has the sleeve on yours been pushed forward and jammed?
Bill.
Previously:
