is this the front O2 sensor? see pics (99 V70 XC AWD)
jtp
Year and Model: 99 v70R
Has thanked: 11 times
Been thanked: 10 times
Re: is this the front O2 sensor? see pics (99 V70 XC AWD)
Post by jtp »
The original picture looks a lot like the rear o2 sensor I just changed this weekend. It looks like it's going into the cat, where the rear sensor goes. holler1's pic looks like the front sensor.
99 V70R AWD
Almost 155K Miles
Breaking is how I know it’s working
98 S70NA (sold)
95 850 Turbo Wagon (RIP)
neworleans
Year and Model: 2007 S60R
Post by neworleans »
holler,
i can't really make it out from your picture because it was taken too close.
I updated m pics and added the arrow so that maybe someone can surely say it is the front or the rear o2.
thanks for your help.
holler1
Post by holler1 »
jtp wrote:The original picture looks a lot like the rear o2 sensor I just changed this weekend. It looks like it's going into the cat, where the rear sensor goes. holler1's pic looks like the front sensor.
Yeah, I think you're right. On my car, the front sensor is right below the turbo. Maybe the 99 is a little different. Here is another photo of mine (front) from directly below.
front O2 sensor from Nov2009.jpg (160.13 KiB) Viewed 4929 times
1998 Volvo V70 AWD 165000-R muffler, HD endlinks, boost gauge
2008 Ford Fusion AWD 107000
2000 Ford Ranger 4wd 172000
1991 Toyota Camry 160000#1
Previous: 1982 Volvo DL (240) 160000
1998 Tacoma, Fords (6), Dodge, Montero,
GTO, Sunbeam Alpine, VW Dasher
neworleans
maybe i should just bring to someone to put it for me?
jtp
Post by jtp »
I really think it looks like your rear sensor but I'm suprised none of the more experienced people has given you a firm answer. If you can show a pic of the side of your car and show how far back it is that might make it clearer.
Even once you ID it though, the rear sensor was really hard to do. If I hadn't read here to buy PB blaster to loosen the sensor it wouldn't have worked. Even then it took about 1/2 an hour of pulling as hard as I could. And you need a good bit of gear, a 12" extension a flexibile joint before the special o2 socket. I don't know what your experience level is but it was right at the limit of what I can do by myself on this car.
99 V70R AWD
Almost 155K Miles
98 S70NA (sold)
confused_al
Year and Model: 1996 TLA wagon
Post by confused_al »
http://www.eeuroparts.com/Main/PartsResults.aspx
96 850 Platinum Wagon
98 MB ML320
06 V70
95 850 GLT(RIP)
mamali
Year and Model: 98 XC70, 95 850
Post by mamali »
I replaced both of my O2 sensors on a 98 V70 XC and still the check engine light is on!!!! We reste it a few times, took the battery off no help at all.
confused_al
mamali wrote:I replaced both of my O2 sensors on a 98 V70 XC and still the check engine light is on!!!!
I wouldn't be surprised if these are eBay specials. Bosch "OE direct fit" is only way to go.
98 MB ML320
06 V70
95 850 GLT(RIP)
neworleans
that is what i bought on amazon, i hope it will work... I think I am going to have my friend install it, since he works at the volvo service, he will be able to reset the system.
Pauloil
Post by Pauloil »
have you done a spark plug before?
an O2 is not much different
go to volvospeed.com and read bay13 about the sensor
chill your anxiety and get under the car and look
if you want, go buy an O2 socket or use the 7/8
the clip holding the wire in is not hard to get out
when I did mine on my 850, I did both
99 V70XC 158K
95 850glt 188K
