1995 Volvo 850 GLT Wont start
confused_al
- Year and Model: 1996 TLA wagon
mamali wrote:A few hits on the fuel tank, put the old (Bad)fuel relay and started right up
confused_al wrote:... give a smack at the bottom of your fuel tank see if your pump comes alive (a new pump should be ordered ASAP);
96 850 Platinum Wagon
98 MB ML320
06 V70
95 850 GLT(RIP)
98 MB ML320
06 V70
95 850 GLT(RIP)
Thanks a new fuel pump will be ordered. A few other issues I have with this toad, turtle whatever is the name. The axle needs to be replaced. The steering is hard turning to one side only. The ABS/ Traction Control light comes on some times not all the time. I think the rest is okay.
confused_al
It must be the fuel pump season upon us, I just saw this on the other forum
http://volvoforums.com/forum/showthread.php?t=36494 pay attention to what Lee is telling you guys.
Since yours is 95, try to clean your wheel sensors w/ brake cleaner first. If no go, check your codes from port A-3 https://www.matthewsvolvosite.com/forums ... hp?t=10758.mamali wrote:The ABS/ Traction Control light comes on some times not all the time.
Try to replace the fluid (ATF) first.mamali wrote:The steering is hard turning to one side only
98 MB ML320
06 V70
95 850 GLT(RIP)
98 MB ML320
06 V70
95 850 GLT(RIP)
Is this the correct fuel pump?
http://www.europartsdirect.com/epc-items.asp
Part# Walbro 70429
Also will I need to drain the tank?
Part# Walbro 70429
confused_al
yupmamali wrote:Part# Walbro 70429
nopemamali wrote:Also will I need to drain the tank?
yupmamali forgot wrote:Do I need new pump o-ring?
98 MB ML320
06 V70
95 850 GLT(RIP)
98 MB ML320
06 V70
95 850 GLT(RIP)
- 1104 Views
Last post by whtwgn
- 472 Views
Last post by screwdriver
