An exceptionally old post at this point, but struggling to get the cover off per your instructions. With the 10mm nut removed on the harness I only have 2-3cm of play, which doesn't seem to be enough to allow the black cover to clear the pump. My cover also seems to only move 5mm of so before getting stuck on something - is there anything holding it to the pump or are there clip-rings retaining it? Perhaps I'm not levering it sufficiently, for fear of breaking something.Matty Moo wrote: 03 Sep 2016, 07:45 Remove the black cover from the pump motor. To do this You need to remove the nut from the harness bundle that is in the way of you removing the cover. Remove that nut, pull the harness out of the way so you can remove the black cover. Don't worry about breaking the black cover, it's very flexible.
Once off... Rewrap each wire individually and reassemble.
Twenty minutes or less.
Need to know removal procedure for the ABS Pump assembly
- Cookeh
- Year and Model: 1996 Volvo 850 T5
- Has thanked: 77 times
- Been thanked: 59 times
- 3800 Views
Last post by davidr002
- 13 Replies
- 3781 Views
Last post by misha
- 1736 Views
Last post by KAGE2020
- 1915 Views
Last post by Hvacman73
- 867 Views
Last post by CSDentonTX
