1990 Volvo 240 DL Charging System Problem
If the alternator is turning , belt tension is not your immediate problem. Your alternator is not putting out. There is a small wire plugged on the back of the alt. Remove the wire, turn on the ignition and check with a 12v test light and see if you have power.
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
If it's putting out 12.4V (which is probably just the battery holding its own charge), the regulator/brushes are toast.Is there a way to check my current regulator to see if it's functioning?
If the belt is spinning the alternator, and you can push on it with a finger and its not slack, the tension is fine.
That current draw seems a little bit high to me, were you able to determine if it dropped with any fuses being pulled?
'98 S70 T5
2016 Chevy Cruze Premier
PaulSimonon
- Year and Model:
Well, I upgraded multimeters today to a more accurate one, and the current draw readings were under 25mA, so I don't think there is anything going on there.
Is there anything I else I ought to check for? Would it be safe to assume that it's the voltage regulator at this point?
1996 Volvo 850 GLT
1990 Volvo 240 DL
1990 Volvo 240 DL
Yup, and make sure you use a little emery cloth on the attachment point under one of the screws on the alt.. It's used for ground.
Also when you're right there make sure the ground strap is good between the alt. and motor mount bracket. They used to pull out on the mount end.
PaulSimonon
- Year and Model:
The regulator is ordered and will be here Monday afternoon. I'll let you all know what happens when I throw that sucker in.
Thanks for all of your help guys, it is very much appreciated.
1996 Volvo 850 GLT
1990 Volvo 240 DL
1990 Volvo 240 DL
PaulSimonon
- Year and Model:
Just installed the new voltage regulator and there was no change. Voltage still dropped once the car was started.
What should my next step be?
1996 Volvo 850 GLT
1990 Volvo 240 DL
1990 Volvo 240 DL
jblackburn
Take out the alternator and have it tested. Advance Auto Parts or Autozone will do this for you.
'98 S70 T5
Did you do this? This is the D+ terminal, the alt. will not work without power given to it. The alt.may be bad, but you have to know if it's getting power or you'll still be scratching your head with a new alt.cattledog wrote:If the alternator is turning , belt tension is not your immediate problem. Your alternator is not putting out. There is a small wire plugged on the back of the alt. Remove the wire, turn on the ignition and check with a 12v test light and see if you have power.
How did the brushes look on the old set?
PaulSimonon
- Year and Model:
I have battery voltage at the D+ terminal.
The brushes looked fine, but there was some corrosion on the regulator itself. The replacement is a new in box Bosch; it looked spotless.
I should have the alternator out and tested at some point this weekend and I'll let you guys know what the results of that are.
1996 Volvo 850 GLT
1990 Volvo 240 DL
1990 Volvo 240 DL
- 12 Replies
- 11508 Views
Last post by warcraftjunkie
- 3049 Views
Last post by dcarlson12
- 20 Replies
- 4079 Views
Last post by bmdubya1198
- 1117 Views
Last post by cracra
- 1314 Views
Last post by 940tvolvo
