99 V70 XC rear washer pump location
I'm replacing mine now and just got it out . The rear pump motor is located on top of the fluid reservoir (the front pump is located underneath). The rear pump has a gray wire terminal connector with a green and black wire. It's just to the front of the washer fluid fill pipe (which can be removed for more access simply by twisting and pulling up). I had already loosened the three 10mm nuts from underneath thinking I had to do so to remove the front pump. I don't think it was necessary but it did allow some wiggle room when twisting the front pump to pull it up and out. The front pump simply pulls out of a rubber grommet in the tank.
Matty Moo
- Year and Model: 850, 1996
- Has thanked: 1 time
- Been thanked: 30 times
I did this today on both wagons.... It isn't incredibly difficult, I did the second one without even jacking the car up. The first took 30 minutes, the second took ten minutes.
What I learned.... Make sure both vent tubes are up and out of the way when you out it back together so you don't have to drop the tank again and fish one out.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
- 36 Replies
- 24791 Views
Last post by StickyPocket
- 15 Replies
- 8781 Views
Last post by volvolugnut
- 4436 Views
Last post by bmdubya1198
- 1553 Views
Last post by Roger_850T
- 17 Replies
- 3009 Views
Last post by 850forum
