Oil drain plug crush washer / sealing washer
prwood
Year and Model: 2001 V70 2.4T
Has thanked: 9 times
Been thanked: 22 times
Post by prwood »
Typically when doing an oil change, I get a replacement crush washer from the local Volvo dealer. For convenience sake I'm trying to see if I can source it from a hardware store. Does anyone know what specifically I'd want to look for in terms of dimensions and material?
Cars I've owned:
- 2015 to current: 2001 Volvo V70 2.4T; 2004 Honda Odyssey
- 2007 to 2015: 2002 Subaru Legacy L Wagon
- 2003 to 2016: 2001 Toyota Corolla LE
- 1999 to 2003: 1994 Toyota Camry LE
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
I won't try it. These are quite specific in terms of material/crushing, etc and the price to pay for a leaking one is an oil change
I'm sure most other sites will have these
https://www.eeuroparts.com/Parts/43088/ ... m-0247804/
Rattnalle
Year and Model: 2004 V70 2.5T
Has thanked: 20 times
Been thanked: 133 times
Post by Rattnalle »
I'd say the opposite. It's a very generic aluminum crush washer. They're not exactly rocket science and are used in lots of places. I'd just copy the dimensions of a spare parts website if I wanted to find them locally. But since you'll need to buy oil filters anyway you might just as well get them together since anywhere you can get the filter should have them.
Has thanked: 1610 times
Been thanked: 4065 times
I must have re-used these 100x by now.Sometimes I clean them up with a file.
prwood
Post by prwood »
abscate wrote: 29 Nov 2017, 11:01 I must have re-used these 100x by now.Sometimes I clean them up with a file.
Over at "Two-Wheeled Texans" (thanks, Google) the consensus seems to be that they are designed to deform when tightened in order to get the best seal between the mating surfaces of the oil pan and drain plug... and apparently most people there, anyway, keep cleaning and reusing them until they start leaking:
http://www.twtex.com/forums/showthread.php?t=5530
They're also known as "sealing washers" due to the seal they make between pan and plug.
Cars I've owned:
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
Dorman have a gift box of 10 crush washers on Amazon. Number is 095-149
Dorman also have a drain bolt with crush washer in a box of 5. Number is 090-167
They are simply named M18 size if you're looking around.
Rattnalle
Post by Rattnalle »
prwood wrote: 29 Nov 2017, 12:28
You can reuse then a few times without any cleaning or anything. I do if I've forgotten to get new ones.
Been thanked: 504 times
Post by cn90 »
I agree with abscate.
My crush washer is still stock after 20y/190k miles.
Just make sure it goes back to the same orientation. The drain plug creates a distinct indentation on one side of the washer. I posted photos in forum.
Georgeandkira
Year and Model: '07 V70 + '15 XC70
Has thanked: 79 times
Been thanked: 71 times
Post by Georgeandkira »
I've seen varying quality at dealerships. The Dorman 10 pack is the best deal you'll find.
Sometimes 3 packs of oil filters from one of the online sellers include them.
A industry specialty hardware store is your only shot of finding them.
If the local parts place has 'em they'e in 2 packs for $4.
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
I also will use any cheap, aluminum crush washer. I periodically reuse the old one too, but prefer to just have a bunch around and swap every change. They are 50 cents each at the parts vendors, buy them in lots of 10.
