my 98 V70t manual swap progress
V70 Automatic to Manual Transmission Swap
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
1998 of that model has no electronic "marriage" of ECM to the other modules on car. Your 2001 has an iron clad marriage with a pre-nuptial agreement, durable power of attorney, and an unalterable will.
If you choose to do a manual it will take custom ECM tuning, adding pedal assy., clutch pedal sensor and its wiring, center console pieces and shifter plus cables, and reverse light wiring all the way to rear of the car. I'm sure there are other things too.
Rotfl, jimmy.
Don't get excited about your anniversary, those of you in the States. Called hose clamp or worm drive clamp here...needs a jubilee clamp
Looking to put 2005 R motor and standard tranny in 2001 70xc wagon Awd. Is this possible, Know need to get clutch pedals and shifter.
does AWD mount up to standard tranny ??
Thank you for your insight
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
Look for an M66 trans from either a 2004-7 S60r or V70R, or a later S40/V50 T5 AWD (MT), they will be set up for the angle gear etc...
Current Volvos:
- 1566 Views
Last post by jblackburn
- 34 Replies
- 9059 Views
- 747 Views
Last post by sleddriver
- 18 Replies
- 3811 Views
Last post by BlackBart
- 13 Replies
- 9159 Views
Last post by nliutilitt
