xeMODex ABS rebuild or OEM ABS unit?
ChrisatXeMODeX
Year and Model: 2013 S60 AWD
Been thanked: 2 times
Post by ChrisatXeMODeX »
Your old BCM might of set speed related codes in the ECM and TCM. You can erase ECM codes using regular OBDII scanner for trany codes you will need VADIS or VIDA.
vailpass
Year and Model: XC70 2003
Post by vailpass »
XeMODeX wrote:Your old BCM might of set speed related codes in the ECM and TCM. You can erase ECM codes using regular OBDII scanner for trany codes you will need VADIS or VIDA.
Thanks. I'm taking it in to Volvo on Monday to have the codes read then cleared.
beaveringaway
Year and Model: xc70 2003
Post by beaveringaway »
I have exactly the same year and model... and the same problem. How did your story end?
