Ok, is there a filter that is accessible in there or do I just replace the pan gasket?jablackburn wrote:Probably so.
I would go with what the above guys said, though...a drain-and-fill a little bit at a time. Drop the contents of the pan and replace that amount, then wait a few weeks and do it again.
How often do you guys flush your ATF?
How Often Should You Flush Your Transmission Fluid?
thecheat
- Year and Model: 1996 850 Turbo Wagon
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Neither. Just pull the plug and let it drain, then put it back in. Just like an oil change
'98 S70 T5
2016 Chevy Cruze Premier
FlyingVolvo
- Year and Model: 2000 V70XC
- Has thanked: 51 times
- Been thanked: 74 times
Thanks!nwhitney wrote:ecbsykes wrote:I do a drain + fill (after having done 4 in rather quick succession) every other oil change or so.
What ATF fluid do you use? Also, welcome back.
I use Mobil 1 Synthetic ATF. It's really good stuff, and it's the only full syn ATF that's easily available (at least in Ca/Az). With the sort of driving I do (often fully loaded, long drives, mountain grades in heat) I really appreciate it's ability to deal with higher stress.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
jblackburn
Just keep doing it like you have been - but, as some have suggested, I might lengthen the interval.
'98 S70 T5
adk793
- Year and Model: 2000 V70 XC AWD/SE
As i was once told, check your transmission oil every 3 oil changes and decide. If it is bright red and smells like ussual ATF, youre good, just keep driving. If it is slightly/severely discolored or has a burnt smell to it, it may be a sign that the fluid needs changing. If the fluid is sludgy brown or black, its a really bad sign something may be really wrong or it has just never been changes.
My S70 has 80k miles on it and I'm not sure if previous owner ever flushed the transmission fluid. Would you suggest just doing a drain and fill, or do you think it's safe to flush it completely and then fill?JRL wrote:Drain and fill every other to every 3rd oil change
Naturally the first time is a flush, depending on the condition and mileage.
I do not flush an (unknown) trans with over 60-70K miles
FlyingVolvo
If I were you, I'd do at least 2 drain and fills first, wait a while, then do the flush (not a power flush from a shop, search MVS for the method with the tube).dmb41 wrote:My S70 has 80k miles on it and I'm not sure if previous owner ever flushed the transmission fluid. Would you suggest just doing a drain and fill, or do you think it's safe to flush it completely and then fill?JRL wrote:Drain and fill every other to every 3rd oil change
2023 V60 T8 PE
2023 V60 T8 PE
jblackburn
^^^That's exactly what I did.
'98 S70 T5
- 11 Replies
- 2740 Views
Last post by oragex
- 11 Replies
- 1213 Views
Last post by MoVolvos
- 1580 Views
Last post by Turbo_Boss
- 24 Replies
- 4178 Views
Last post by bigbrain
- 31 Replies
- 5632 Views
Last post by VolvoOwl98
