Strut issue
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
To the both of you - grab that top nut with a wrench and push on it a little bit (you'll need quite a bit of pressure to loosen that thing, so don't worry about popping it loose). If the whole spring seat spins around - or moves in either direction AT ALL, the spring seat is dead & needs to be replaced. I used the XC90 ones to replace mine.
'98 S70 T5
2016 Chevy Cruze Premier
Metalbonder
- Year and Model: 850 1997
Cool, is the XC90 one better? They look the same on the fcp groton site.
jblackburn
They're a bit more heavy-duty construction, and should stand up to a few more years of use than the standard ones.
'98 S70 T5
- 11 Replies
- 8052 Views
Last post by BackRoadSeeker
- 2389 Views
Last post by oragex
- 721 Views
Last post by oragex
- 1198 Views
Last post by Vovo_merz
- 920 Views
Last post by BEJinFbk
