Engine Mount Discussion
valvster
Year and Model: 850 1996
Post by valvster »
confused_al wrote:
valvster wrote:I am thinking twice about poly bushings for the upper mount so spotted this heavy duty one on a UK parts site last week.
Hopefully it will be the last one I install on the car.
For the top mount, Volvo's MSRP is 20USD, often we can buy from online dealers for $14 ish, yet that site wants $29 for that? Not to mention most of Meyle parts are made in china.
Sadly Volvo carparts are exorbitant in Australia compared to USA.
8 years ago I put in the genuine Volvo top mount it cost me A$90 so $29 is cheap for me and it was included as part of a shipment of several other parts from the UK which turned out cheaper overall than the same parts purchased from the US only because of postage costs (UK is cheap postage compared to US as a lot of US stores only use Fedex) .
A Scantech coolant expansion bottle costs A$125, didn't even bother to find the cost of the genuine part so sourced one from UK.
Back to the mount....it certainly looks better made than the original Volvo part with additional rubber shoulders where they normally split and all encased in a metal tube.
I used to be concerned about Chinese manufactured goods but now I figure German robots work just as well in China as they do in Germany, I guess we have to rely on the manufacturers with reputable names to produce quality goods no matter where they are made.
Valvster
V70r carbon
Year and Model: 2005 v70r
Post by V70r carbon »
Can anyone say if bad lower engine mounts could cause a vibration through the clutch pedal at lower RPM's? Or am I looking at a clutch replacement? The pedal rattles between
1500 to 2000 revs when starting up, but when the engine settles to normal idle and the clutch fully depressed, it's fine. Give it a blip on the gas, I feel it through the pedal and can hear it also. There isn't any slip at all. Any ideas?
Clemens
Has thanked: 500 times
Been thanked: 228 times
Post by Clemens »
Might as well be. I started hating my 96R this winter when the lower (front) engine mount went bad. Everything vibrated. After replacing it everything is alot smoother, including shifting. So I´d give it a try, especially since parts are faily cheap and the replacement job is a walk in the park.
1996 855 R,
2010 V70 D5,
98v70dad
Year and Model: 98 V70
Has thanked: 1 time
Post by 98v70dad »
I replaced all of them except the frame bushings with OEM parts and I still get an annoying buzzy feeling vibration from the front. I'm beginning to believe its something internal or misfiring. My car has 162,000 miles on it. I don't know if this info is helpful to you but all new OE mounts and a persistent vibration is a data point for you.
jmartin919
Year and Model: S70 GLT SE 2000
Has thanked: 97 times
Been thanked: 42 times
Post by jmartin919 »
98v70dad wrote: 28 Mar 2017, 17:18 I replaced all of them except the frame bushings with OEM parts and I still get an annoying buzzy feeling vibration from the front. I'm beginning to believe its something internal or misfiring. My car has 162,000 miles on it. I don't know if this info is helpful to you but all new OE mounts and a persistent vibration is a data point for you.
Any luck with this vibration issue?
'00 S70 GLT SE
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
