open door chime
kurtio1965
Year and Model: V70 1998
Re: open door chime
Post by kurtio1965 »
I have a 98 v70 with the exact same issue. I can not lock the vehicle until this is resolved. I tried the WD trick with no results. It used to be if I put the key back in the ignition, put the car in neutral and then "firmly" back into park, that would do the trick. But no more.
Auburn T5
Year and Model: 1999 S70 T5
Been thanked: 2 times
Post by Auburn T5 »
There is actually 2 tiny little switches on the door lock mechanism that trigger when the door is closed. These switches eventually fail. For 98 and older, you can remove them and solder on replacement switches but as I discovered with my 99, I had to replace the entire locking mechanism to fix the problem.
Scroll down on page 2
https://www.matthewsvolvosite.com/forums ... 3&start=14
Here is a post showing how to replace them
http://forums.swedespeed.com/showthread ... k-switches
And here is the part you need. The assembly uses 2
http://www.mouser.com/Search/ProductDet ... -1055.2351
2020 - Tesla Model 3 Performance
2020 - XC60 T5
1999 S70 T5 - Bilstein touring shocks/struts, B&G S2 springs, OBX full exhaust, other misc. stuff
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 93 times
Been thanked: 146 times
Post by BEJinFbk »
IIRC, one switch operates the red safety light in the door jamb
and the other shows a ground to the central locking module ( chime ).
