open door chime
aquavolvo1
- Year and Model: 1995
Am i the only one that has to hear the door chime telling me my drivers side door is open all the way to work each morning when the door is, indeed, closed?
- Year and Model: Many Volvos
- Been thanked: 76 times
Chances are the door lock mechanism is messed up. The switch that tells the system that the door is closed is actually part of the locking mechanism itself.
If you want to shut things up you can remove the chime itself - it is located high on the firewall in the lower electrical center just below the main fuse box. The relay is number 212 and it is normally blue in color and it has slits cut in the end of the relay. Just unplug it.
i came very close to adding that but I thought it might be confusing so +1.Don't forget - If the domelight fuse blows, the chime will go nuts...
GlennKorec
- Year and Model: 2004 V70R
My door chime is on when the door is opened and no key in the ignition. Once the door is closed the chime shuts off. As if the chime is ringing to remind me the key is in the ignition, when in fact it is not.
Glenn
Glenn
Glenn Korec
Syracuse NY2005 S40 T-5 Auto Triple Black (Wife's)
2004 V70R Black with Nordkap Interior
Former Cars:
98 S70 FWD non turbo silver
99 V70 FWD non turbo (moondust ??)(wife's)
Former Cars:
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
That's probably the little switch in the ignition that detects if there's a key in it or not.
I've heard tell that a short, sharp shot of WD will happify that little guy.
I have a 1998 V70 with the same door chime issue, plus the door light is on if I don't slam it regardless of whether the key is in or not. I kill my battery finally. Is there a fuse or relay that will kill both?
Thanks,
MIke
Thanks,
MIke
- 900 Views
Last post by m491
- 677 Views
Last post by matty0
- 442 Views
Last post by IG-88A
- 1164 Views
Last post by bmdubya1198
- 948 Views
Last post by Dizio
