dirty rims
tjts1
- Year and Model: 96 855 NA 5 speed
- Been thanked: 4 times
Re: dirty rims
Clean it, sand it, prime it, paint it. No point in trying to save 15 year old wheel paint.
Ambitious but rubbish
Allen in Hemet
- Year and Model: 2000 V70XC SE
Then, after you have cleaned and/or repainted the rims, and after the brake pads have worn down, replace the front brake pads with Cereamic pads. Available on line at Carparts.com, partstrain.com, and your local Autozone store also have them. Ceramic pads don't create black dust and have very good braking characteristics. R/ Allen
mindshadow
- Year and Model: none
Get some P21s (gel if you need some extra cutting power). It absolutely won't damage your wheels and it cut through brake dust that I was certain nothing would remove. Looking at the photo of your wheels, that's nothing compared to how mine looked before. Now they look brand new. Use the Matthews Amazon link up top and search for P21s so the site gets the referral link.
mikealder
- Year and Model: V70 2000
- Been thanked: 13 times
Not too sure the stuff I use will be available in the USA, I use a trigger bottle made by "Astonish" its just labeled up as Alloy Wheel cleaner, costs under £1 and works great, spray on, agitate with a soft brush then rinse with water, under £1 and you get enough to clean all four wheels at least eight times each - Mike
cdnbluez
- Year and Model: 09 C30/98 V70/99 S70
- Been thanked: 3 times
OK, so I just picked up a set of Columba's today. They are from a '95 850 and are pretty dirty. Came with decent tires, $200. I bought some Greased Lightning, it worked pretty good. The caked on black spots are hard to remove. It will take a few tries. It was getting cold so I gave up. Here are the results
- Mounted on a dirty car! They'll be coming off before it snows again.
- IMG_0831.JPG (300.79 KiB) Viewed 980 times
- Most of the brown stuff came off, but the black dry tar-like stuff is hard to remove. I left one area untouched.
- IMG_0819.JPG (123.63 KiB) Viewed 980 times
- IMG_0818.JPG (134 KiB) Viewed 980 times
- Couldn't resist, had to post pic after car wash.
- IMG_0849.JPG (252.98 KiB) Viewed 963 times
2007 C30 T5 6 Speed
2005 S40
2006 XC70
2014 Mercedes E350
1996 Corvette Convertible LT4
Previous Volvos:'09 C30 5 speed, '99 S70, '99 S70 5speed, '98 V70 SE, '04 XC70, '01 V70, '02 V70 awd, '97 855, '90 745 Turbo+, '90 745 16v, '89 780 Bertone Turbo+, '86 760 Turbo+, '82 240 GL
2005 S40
2006 XC70
2014 Mercedes E350
That wheel doesn't look TOO bad... buy wheel cleaner with acid in it (look on the bottle, most say there is only a surfactant in it but you want the acid) and spray it on, wait 30 seconds, then rinse it. Don't leave it on and especially make sure it doesn't stay on the rubber as it can whiten it.
If you use it sparingly it won't cause too much damage to the paint.
