trstjohn: I can't comment on the hand pump bleeders, I have always used compressed air (http://www.harborfreight.com/brake-flui ... 92924.html) But as long as you can get a good bleed on each brake caliper and know that you have the most air bubbles out, then you should be good.
This is certainly one area to look at as you investigate the vacuum pressure and ensure that is operating properly, as jimmy57 mentioned.
Brake lag after starting
TexasCoder
- Year and Model: 2004 XC90 T5 AW Tran
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
The exhaust cam is advanced and timing is less advanced on all starts below approximately 125F coolant temp. These actions reduce engine produced vacuum.
The test for this is simple. If you turn on key and depress brake pedal you should hear vacuum pump usually on second "pump" of brake pedal. If you get hard pedal and you do not hear pump running then find out why.
The pump is fitted to these for your exact complaint so it should be checked before you spend time on causes less likely to contribute to braking difficulties after engine is started cold.
jimmy57
The problem is gone after engine runs for a few minutes is what I'm understanding.
IF vacuum pump is functioning properly, and it is from doing the test, the booster is suspect.
I'm also working on the assumption your problem is really no normal stopping with normal brake pedal apply force when this is occurring but harder brake pedal application does make the deceleration greater?
I'm still stuck on the vacuum pump. The vacuum pumps have given enough problems that are related to the switch. Either running continously when vacuum is high enough to have shut it off or running very briefly when vacuum is low enough tht it should be running much longer.
If I were working on it I'd have a vacuum gauge T'd into hose to booster and check for vaccum levels when pumping brake pedal with engine off causes pump to come on and at what vacuum it goes off. On when goes down to 14 inches and off when it builds to 18-20 inches is normally observed.
WinterDriver
- Year and Model: 2004 XC90 T6 AWD
Actually if you read in your owners manual it will actually tell you if the brakes are cold, or wet, brakeing time is increased. Also that is why you should let your car idle down to 1.5 rpms before moving.
I'm still getting the lag even in dry warm weather.... Something else must be going on....WinterDriver wrote:Actually if you read in your owners manual it will actually tell you if the brakes are cold, or wet, brakeing time is increased. Also that is why you should let your car idle down to 1.5 rpms before moving.
2003 Volvo XC90 T6
2007 Volvo XC90 3.2 (Wifey)
stone36
- Year and Model: 2005 V70R and XC90
Mine does this too, very sporadically and only when first pulling out of my parking space, but I find that if I notice the pedal is hard right away and take my foot off the brake pedal and then push it again it works fine. As for a bleeder, I have the one from MOTIV products, it is about $50 but comes with the cap for Volvo and it works on all Volvos. I have bleed the brakes twice and that doesn't fix the problem, there is something other than air going on. But it happens so infrequently and my "pump the pedal once" trick has so far been 100% successful...
05 V70R TiKap (so happy) 91K
05 XC90 2.5T FWD TiBlak 97K
94 850 wagon 2.4 (N/A) 155K (Sold running like a champ)
- Has thanked: 2857 times
- Been thanked: 1332 times
This sounds similar to a problem with my 2004 V70 -- https://www.matthewsvolvosite.com/forums ... =9&t=36775
I finally decided to get an expert opinion on the brake lag. I took it to my mechanic and he said I need a new vacuum pump as you suggested. He estimated at $1k for a new one (IPD is telling me $250). BTW, he always seems to over estimate how much parts costs. However, he did, off the record, say that a 25V fuse would alleviate the problem.jimmy57 wrote:The exhaust cam is advanced and timing is less advanced on all starts below approximately 125F coolant temp. These actions reduce engine produced vacuum.
Any thoughts on the 25V fuse?
2003 Volvo XC90 T6
- 2191 Views
- 1221 Views
Last post by Homebrand
- 3382 Views
Last post by RussB
- 22 Replies
- 4106 Views
Last post by alexv702003
- 759 Views
Last post by PeterBagge
