I guess my answer to the poll is no, and I hope I can keep it that way.
I've got a good bit of oil leaking in the viscinity of the turbo on my '98 S70. Could it be the oil return line or something more dire? I've also noticed that my turbo is a little louder recently and likes to really zoom after I park. Normal?
Had a problem with your 850 or 70's turbo?
Having Trouble With Your Volvo's Turbo?
RC850T
I concur with Alan J - a properly maintained turbo should outlast the rest of the car. Water cooled units have altered the old model, and it is no longer a situation where the question is not if the turbo will fail, but when the turbo will fail. I very recently had occasion to know what kind of shape mine is in; my '96 850 T-5 suffered a burned valve (FYI, cyl #3 exhaust) just shy of 175,000 miles halfway through a 200 mile trip. When the upper end was later disassembled I had the opportunity to check out the turbo and find it in pristine condition; i.e., smooth running, tight bearing movement. Since I've owned the car (~68,000 miles) I've run Castrol synthetic, which I change at more frequent than required intervals, and use Volvo (Mann) filters. To me, given the high-heat, high-speed conditions under which a turbo operates, this just makes good sense.
On a related note, while I was in turbo mode (so to speak), I shortened the rod on the wastegate actuator to increase the boost from the wimpy 4.5 psi factory setting (my '88 740T had 10.5 psi from the factory) so that it now approaches 10 psi (according to my IPD boost guage). The result has made me very happy.
sckerber
The turbo has been leaking oil since I bought the car at 135k. It now has 191k. It is not the oil return line which is relatively cheap and easy fix. Mine runs through the whole induction system: intercooler and manifold. At some point I imagine it will seize up or something, so far I get good boost and performance. There are drips down the back of the engine and oil spots on the driveway.
If anyone is contemplating replacement I would suggest www.fcpgroton.com it wasn't in their parts list but call or email them; a rebuilt turbo runs about $900 w/ a $200 core charge. They are helpful and knowledgeable and have good prices on most anything you'll need.
robert213
- Year and Model:
My nominations for shops where you can have your current turbo rebuilt professionally. It shouldn't cost much more than $300. Remember to install a new turbo oil feed line.
And one other thing... For the price of a rebuilt, your existing turbo housing can be over-bored for a larger compressor wheel, such as -15G, -16G, -16T, or -17C.
Oh and if you would rather, these places sell brand new turbos, too.
Shop and Compare...
http://www.forcedperformance.net/
Forced Performance
671 New Hope Road West
McKinney, TX 75071
Phone: (972) 984-1800
Fax: (972) 984-1802
[email protected]
[email protected]
http://www.turbochargers.com
Turbochargers.com
5410 Burr Oak Drive
Houston, Texas 77092
Tech Line: (713) 681-1111
Order Line Toll Free: (800) 749-7111
Fax: (713) 939-1111
Email - [email protected]
http://www.dallasturbo.com/
Majestic Turbochargers of Dallas
1000 S. Wildwood
Suite 10
Irving, TX, 75060
http://www.hirschinds.com/
HIRSCH FOREIGN
P.O. BOX 18063
PHOENIX, AZ 85009
Shop and Compare...
Forced Performance
McKinney, TX 75071
Fax: (972) 984-1802
[email protected]
[email protected]
Turbochargers.com
5410 Burr Oak Drive
Fax: (713) 939-1111
1000 S. Wildwood
Suite 10
Irving, TX, 75060
HIRSCH FOREIGN
P.O. BOX 18063
PHOENIX, AZ 85009
h2oiamwater
- Year and Model:
welll i just got my 850 8 months maybe nad old people before didnt take care of it so im smoken hella bad on another forum they say its my turbo... os i think ima be gettin a new orused one dont really wanna bust 1800 for one
beating a honda is like doin your mom, anyone can do it...but who wants to brag
95 850 turbo
95 850 turbo
No, But I'm not entirely sure if my turbo gauge (on the dash) is reading correctly. If you are foot to the floor, what should the dial read??
(Excuse me for sounding like a dufus on thi, but I have little experiance with turbos. . . . .)
Cheers
N
Cheers
N
1996 850 T5 154,500 miles
MadeInAmerica
- Year and Model:
Check your intercooler hoses to start off with for leaks and loose clamps. Then do the same thing with all your vacuum hoses. The elbows for the vacuum lines get mushy and leak-need replacing. If you never did any of this you definitely need it done.
'94 850 Turbo 160K Automatic
[Autometer Sport/Comp Boost Gauge][Silicone Vacuum Hoses][Walbro Fuel Pump][New OEM Torque Mount][Yokohama YK520][New PCV system+Air Intake Hose][Magnaflow Cat at 160K][Borla Pro XS Muffler 162K]
turbo4door
- Year and Model:
2000 s70. no turbo problems so far.. 129000 miles and still smooth..
- 1352 Views
Last post by erikv11
- 1033 Views
Last post by xcvolvoist
- 31 Replies
- 5542 Views
Last post by VolvoOwl98
- 1735 Views
Last post by traudesa
- 1585 Views
Last post by EuroDriver
