850 code 2-3-1 problems
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
The most common test is to pull out the oil dipstick with the engine running and warmed up to look for smoke. A small slip of paper should be sucked in slightly to the opening, indicating that the system is venting properly.
'98 S70 T5
2016 Chevy Cruze Premier
easyrhythms
Year and Model: 1994 Volvo 850 Turbo
Post by easyrhythms »
well i think the pcv system may be my problem then. there is some smoke coming out of the dipstick so I took it to a shop this morning (quite an endeavor because the car stalled out the entire way lol). i'll post whatever i find out.
Mjollnir
Year and Model: 850 T5-R 1996
Post by Mjollnir »
Hi everyone, I'm the first time poster as well.
Responding to the topic - check ignition distributor cap (and a rotor of course). I had an exactly the same problem - a 2-3-1 code.
Every few days I had to reset ECU in order to enjoy ride with full boost. Replacing cap and rotor solved the problem.
Best of luck.
