850 rear brake issue
superfing
Year and Model: 96 volvo 850 Wagon
Has thanked: 2 times
Re: 850 rear brake issue
Post by superfing »
middle I believe. I can post a pic soon, waiting for my other parts to come in to remove the tire again.
96 Volvo 850 wagon
85 Volvo 240 Wagon DL
polskamafia mjl
Has thanked: 19 times
Been thanked: 21 times
Post by polskamafia mjl »
Rotors generally have 'lines' on them after they have been used a few times but there shouldn't be any deep groves or anything. A pic will be most helpful.
superfing
Post by superfing »
I replaced the shims today and had failed to notice that the wheel that was squealing the loudest does not have the centering screw that goes through the rotor. The rotor has a little wobble with only the caliper, this has to be the culprit. I am going to order one tomorrow.
96 Volvo 850 wagon
vjaneczko
Year and Model: 2006 S60R
Been thanked: 6 times
Post by vjaneczko »
Even without the 10mm pin-nut thingy, you'll be able to keep the rotor true by taking time to tighten the lugs. Tighten by hand in the regular star pattern, then tighten with a torque wrench to 81 lbs. That will sandwich the rotor between wheel and hub quite well.
1997 855 GLT - R.I.P.
2006 S60R - For ME!
