Bought a V70 T5 with Suspension and Springs, WAY TOO STIFF
zhenya
- Year and Model: 97 855 T5,98 V70 AWD
Re: Bought a V70 T5 with Suspension and Springs, WAY TOO STI
I guess I should clarify that I was asking the OP if any of those items are present, because they can have a significant impact on the ride quality.
JRL
- Year and Model: Several
- Been thanked: 16 times
You're running WAY too much tire pressure. Running over 36 will make your car like a ping pong ball.
You MUST run 30-33-34 TOPS For an unloaded, (nothing or no one in the rear).
FWD car you should run a bit more in the front than the rear, 32-33 front, 31 rear, less understeer
You also have a NON high performance tire, lower the pressure, live with it, or buy a proper performance tire
JRL
Koni yellows are NOT stiff at allzhenya wrote:Any other performance parts on there? Upgraded sway bars or front strut bar? The only widely available shocks that have a reputation as being overly stiff for this platform are the Koni adjustables and Bilstein HD's - both of which are yellow.
Please don't post something that you "hear"
zhenya
What else are we able to do with much of the advice we get and give here? I can tell you what the experience is with the particular suspension I have owned and driven, and would you not believe me? I'll say it again. Adjustable Konis have a reputation as being stiff. Is that because many people adjust them too stiff, and then report? I don't know, but I'm not giving buying advice here - I'm asking a question trying to figure out what his issue might be. Chill out.JRL wrote: Koni yellows are NOT stiff at all
Juan62
- Year and Model: S70 T-5M 1998
- Been thanked: 2 times
I've heard many times while in Germany, that Eibach springs are very stiff, but great on performance. Check out Koni FSD, I'm hearing nothing but great things for these struts. Remember to purchase OEM parts for the suspension outside the struts/shocks and IPD HD spring seat mounts. I'm going to purchase the Koni FSDs this summer.
98 S70 T5-M Brick for life
zhenya
I'm very happy with my FSD's, which are paired with Eibach springs.
In any case, the trick with suspension is that everyone's threshold for what is acceptable is different. What is perfect for me is going to be way too stiff for someone else.
98V70T5
- Year and Model: V70 T5 1998
I am basing the psi recommendations based on Volvos numbers. Inside the fuel lid it gives you a base setting, then a high speed/best fuel economy setting. Has it been discussed on here that Volvo's numbers are way off?JRL wrote:You're running WAY too much tire pressure. Running over 36 will make your car like a ping pong ball.
Thanks
98V70T5
Nope all bone stock. Thanks
98V70T5
zhenya wrote:I'm very happy with my FSD's, which are paired with Eibach springs.
I rode in a newer 3 series BMW with lowering springs, and coilovers. It takes railroad track crossings like buttah, and gives a really really firm compliant ride. Its like having the best of both worlds. Sudden jolts it absorbs, but for cornering, its on rails.
If I lived where the roads are baby butt smooth, like when I visited Utah, I wouldn't really touch this car, but its way too jarring for these NE roads!
- 1023 Views
Last post by precopster
- 2149 Views
Last post by oragex
