NO Be carefulDan Hanvey wrote:OK - So I burned through a 22oz can of refrigerant and the PSI is still about 30 - so thinking I need another can. On the plus side - the clutch is staying engaged and the car is blowing cold - WoooHooo since I live in the high desert it has been 100 degrees plus lately.
Thanks for the help ya'll
These cars take 1.65 lbs which is a hair over two cans and the 4 oz difference isn't enough, it should be cold enough if everything else is nominal
22 oz should have been enough even if it was completely empty. If you want to add another 1/4 of a 12oz can, that should fill it
TTT!
