Air conditioner not working leak on bottom of accumulator
Switchemlee
Year and Model: 1998 v70 xc awd
Post by Switchemlee »
Hi I'm trying to figure out how the process of replacing the ac accumlator (dryer) on my 1998 volvo v70xc. It has a huge hole in the bottom of the canister.
jreed
Has thanked: 384 times
Been thanked: 221 times
Post by jreed »
One of the longtime leaders on this site (Ozark Lee) wrote up a description of tools needed and procedure for changing it out here:
https://www.matthewsvolvosite.com/forums ... hp?t=64132
Clemens
Has thanked: 498 times
Been thanked: 228 times
Post by Clemens »
Depending on if you have the tools to refill the system yourself or not: i had my indie do it, it took them 15 min or so and then a bit to refill the system.
1996 855 R,
2010 V70 D5,
Has thanked: 1610 times
Been thanked: 4065 times
There are some big nuts (22-23mm?) on the accumulator that will be tough to break. It's hard to get a big tool down there in that space without taking out a lot of stuff.
Definitely replace Orings and, if the system has been open to air for a while, this can get expensive. You will need a full charge of PAG oil too, most of it resides in the accumulator and my guess is it's PAG ing the road somewhere
