1990 760 turbo
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
ldou0110
Year and Model: 1990
Re: 1990 760 turbo
Post by ldou0110 »
Thanks for your reply. I was always told right rear l rear f right f left/ will try your way Thanks again
ldou0110
Post by ldou0110 »
Manual bleed. No fluid coming out of the pump assembly To the front left slight fluid seep to right front good pressure to rear I think. could it be the relays on the pump assembly or the pump assembly. Is there a way to check either. would it make a difference to have the key on when bleeding or start the car
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
This is from a Volvo publication.
760 ABS brake bleeding.JPG (31.96 KiB) Viewed 1296 times
Apart from the difference in the wheel sequence ABS brakes should bleed in the same way as non-ABS. If you are still having problems you may have a blockage in one of the brake lines or one of them may be kinked.
A pressure bleed is a much better option.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
ldou0110
Post by ldou0110 »
Thanks Bill I will try that tomorrow, but I think I only have one bleed valve on the front calipers and two on the rear. If there is two on the front I have missed the bleeders I'm seeing are on the top. Have I missed something.
lummert
Year and Model: 760 1988
Been thanked: 26 times
Post by lummert »
The 88-90 Volvo 760 has ABS which means it only has one brake bleeder on each of the front calipers and one brake bleeder on each of the rear calipers.
1988 Volvo 760 Turbo Wagon
ldou0110
Post by ldou0110 »
alright attempted the bleed as directed get some pedal no fluid to the left front . Replaced left front caliper did bleed as directed have I think good fluid to all calipers but soft pedal. With engine running pump up and fluid is strong at all wheels, engine off weaker any Ideas? Feel like I have a air leak but see no fluid and have no idea where or how to find it. Had no idea this was going to be this challenging,but have to finish at this point. Going to try to find a pressure bleeder.
Larry
lummert
Post by lummert »
I think you still have air in the lines.
ldou0110
Post by ldou0110 »
Bill
I did the bleed as directed, still no or little fluid to the front left, very little pressure to the r Front. Replaced the left front caliper, did bleed finally got pressure both front and rear still have soft pedal and seems to leak off. Put in gear on blocks and will stop rear wheels but leaks off and have to pump next time. The rear end seems to move a lot, doesn't seem right. Think I will try to find a pressure bleeder, feel like still have air in lines. Any Ideas
Thanks
Larry
ldou0110
Post by ldou0110 »
I have one bleeder on the front calipers and two on the rear. I'll try bleeding more
