1990 760 turbo
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
ldou0110
Year and Model: 1990
1990 760 turbo
Post by ldou0110 »
Will not start. Getting fire is not getting gas. Removed two spark plugs skirted fuel, it tried to run until fuel ran out. replaced in line pump and filter. still not running.any ideas
larry
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
Have you checked fuses 30 & 31 and the fuel pump relay?
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
ldou0110
Post by ldou0110 »
where is the relay located. The fuses are OK
lummert
Year and Model: 760 1988
Been thanked: 26 times
Post by lummert »
The relays are behind the radio console. You get at them by removing the cover panel under the passenger (LHD) side dash.
1988 Volvo 760 Turbo Wagon
ldou0110
Post by ldou0110 »
Thanks for your help, fuel pump and filter did the job. A friend came over to help and left a fuse out replaced and car started. working on the brakes, pedal is soft. checked fluid its fine,pulled front calipers pads are good. seem to be dragging more than they should. Brake lines are worn, plan to replace. Any suggestions?
lummert
Post by lummert »
Are you saying the brake lines are worn or do you mean the brake hoses are worn? The brake lines are made of some kind of alloy. The brake hoses have been known to swell internally and not allow the fluid to return to the master cylinder, which could cause the brakes to drag.
ldou0110
Post by ldou0110 »
I'm sorry, hoses they are probably original so will replace thanks.
ldou0110
Post by ldou0110 »
Help replaced the brake hoses, bled off, have fluid to all four wheels, pedal goes to floor. Not much pressure to any of the wheels. I'm thinking the master cylinder
ldou0110
Post by ldou0110 »
drained fluid checked all caipers seem to be working. Have fluid to all wheelsm except the left front. cheked lines to ABS modual ????? and out alll lines have fluid except the line going to the left front. Any Ideas please
billofdurham
In what order are you bleeding the brakes and are you doing a manual bleed or a pressure bleed?
The correct order for the 760 with ABS is Left front, right front, left rear and right rear. This is different from the order for non-ABS.
Bill.
Previously:
