MAF replaced with generic MAF -- 98 V70 running very poorly!
Gentleman Mac
Year and Model: 850 1995
Re: MAF replaced with generic MAF -- 98 V70 running very poo
Post by Gentleman Mac »
Looks good to me.
1995 854 167k
1998 v70 glt 166k
misha
Year and Model: '97 850 2.5 20v
Has thanked: 152 times
Been thanked: 402 times
Post by misha »
Yep,that's the front one.The rear one is #15062.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
boosted5cyl
Year and Model: '98 V70 T5, '99 S80
Post by boosted5cyl »
For what it's worth, I put a POS no-name reman MAF from O'Reillys in our T5 30K miles ago, car has about 213K on it now.. Zero problems with this MAF so far. However I did do an adaptation after I changed it. I know the consesus is to use bosch, but since you already have a generic one in there you might try an adaptation as well as a NEW set of plugs, gapped correctly.
Are you sure the connection and cabling for the MAF are good? Any CEL? The symptoms your describe are not typical of a dud O2 sensor, moreso a vacuum leak or a MAF signal that the ECU doesnt like. MAF is easy to isolate though, just as you did before, start the motor up with the sensor disconnected. Given your miles an O2 is a good idea, but I doubt it going to remedy the erratic running you are seeing,
'04 XC90 2.5T AWD (Angus) 134K.
'99 S80 T6 (Medusa) 214k. On borrowed time LOL
'98 V70 T5 (Vivienne). RIP @ 228K. Spun rod bearings.
