Timing belt seems to be in perfect condition. Have rechecked everything again today. It just won't start. Great spark. Great fuel pressure. Sounds like it will start, but never does.
Bettery fine
Pressure regulator fine
Plugs and wires fine
Starter fine
Alternator fine
Thermostat fine
Ignition coil fine
Fuel pump/filter both fine
Repaired fuel pump relay.
I'm literally out of ideas.
Exhausted all ideas, still not cranking
trackminer
- Year and Model: 1999 S70, 1986 244
I'm willing to bet that this issue is directly related to either the cam position sensor or the crankshaft position sensor...if your vehicle is so equipped...
...pullin' off slow - in a VOLVO...
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Here is the code list:ShadeTreeNikki wrote:... I pulled the codes.But all of the codes aren't listed on the link. Here are the codes. Hope I'm getting somewhere.
A-1 124. A-2 113,221, 121, 512,311. A-6 411. A-7 111.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
trackminer
Though this happened on a 97 850, this may help out...
https://www.matthewsvolvosite.com/forums ... 0&p=202154
ShadeTreeNikki
- Year and Model: '93 850
Thanks trackminer. Will replace tomorrow if parts are available. Let you know how it turns out. Thanks again everyone.
trackminer
Hello Sir! Has your issue been resolved..?
ShadeTreeNikki
Hey, been waiting to respond. Hoping to have an answer for the boards. At this point. Nothing worked. I tried everything. Replaced all that I was advised to replace. Still did not start. It was close to starting several times, but didn't actually start. I ended up having to tow it to an imports mechanic shop. The owner was a Volvo dealership mechanic for 23 years. I'm confident that something will be known today or tomorrow. Will update as soon as I know.
Thanks again for all of the help everyone!
ShadeTreeNikki
Cam replaced prior to tow. Tried... it didn't start. Waiting for 2nd call tomorrow.
- 3782 Views
Last post by FLXC90
- 17 Replies
- 3199 Views
Last post by darrenroark
- 25 Replies
- 10998 Views
Last post by erikv11
- 1649 Views
Last post by s60andyskinner
- 563 Views
