Not enough power to the door lock actuators
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
The PTC is there to save motor from a stuck relay. When the 240's used a two changeover relay system to operate door locks with crude switch clamped around door lock cylinder, the switch would fail or a relay would fuse contacts and stick on. PTC was introduced for this.
The Denso lock control module on x70's has no history of that.
The newer cars with network have no PTC's but are a completely different
If you ever operated your working locks multiple times, like testing remotes, and you noticed one or two just quit but later worked normally, that is the PTC doing its thing.
whoa
- Year and Model: 850 Turbo Wagon 1996
Well if you (jwebster) have one that had not failed, and you have an ohmmeter, would you be willing to measure the resistance at room temperature and after sitting in your freezer for an hour?
1996 850 Turbo Wagon
- 5049 Views
Last post by jonesg
- 257 Views
- 255 Views
Last post by BrandynKunde
- 71 Views
- 1122 Views
Last post by eitankon
