Repeated P0422. Cat does not rattle. Purge valve or O2?
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2856 times
Been thanked: 1332 times
Post by matthew1 »
jblackburn wrote:Do the air pump and associated parts WORK? That could be causing the efficiency code right there! (although when mine started going bad, I kept getting air pump codes just about every day or two. Very annoying.)
You should hear it start up in the morning once the car is put in Drive and driven a few hundred feet.
Now that you mention it... I used to hear it, or rather the infamous "ghostly moan" in the colder weather. I haven't heard it this year. It has even snowed twice in the last week, and I drove in the snow both times. :shock:
SAS Delete, pronto.
Hey this forum is pretty good.
Also -> Amazon link
Has thanked: 1610 times
Been thanked: 4065 times
If it is a late model with an ETM, the cruise may become disabled when the check engine light is on (not 100% sure of this but may be a possibility
On my 1999 T5 some engine codes will definitely disable the cruise control. An ETS light or ABS fault will also do this.
jpr0204
Year and Model: 12' XC70 Prem. Plus
Post by jpr0204 »
Afternoon All,
I know this thread is a bit on the old side, but Matt, What if you build your own evap smoke machine fro cheap and tap into the evap system and smoke it out to see where the leak is?
That's normally what I do when I have a car come in with an evap leak. +
I remember one time a customer brought his 02' Oldsmobile Silhouette in for a P0445 "large leak detected" code and had brought it to several shops who replaced everything under the sun (i.e. vent valve, purge solenoid, vapor canister, etc...) to "fix" it but to no avail, the light remained on. Turned out that about 4 weeks earlier he just had a new fuel pump module put in the tank and when they tightened the lock ring down around the pump they crushed the o-ring. I hooked up the smoke machine and immediately found smoke coming out of the top of the tank where the pump went in, put in a new o-ring and it was night and day.
- Joe
Current Vehicles:
20' Kia Sorento (Lease) (Fiancé's car) Currently at 19,500 miles
12' Volvo XC70 Premier Plus AWD Currently at 95K miles
12' Yamaha V-Star 950 EFI Tourer (My daily summer crusier) Currently at 5K miles
04' Yamaha V-Star 650 Classic (Fiancé's daily summer cruiser) Currently at 16K miles.
matthew1
Site Admin
Post by matthew1 »
Thanks abscate. My cruise continues to be non-functional, but I don't do any long-distance driving.
Joe, thanks for the ideas. I put this P0422 on the "shelf" because it sometimes doesn't show for up to 2 months. Besides cruise, there are no symptoms. It's frustrating, but on a low level. I'm going to get after it again when the weather gets better.
I'll try a bunch of incense sticks first -- the (very) poor man's smoke machine. Then if nothing turns up, SAS delete.
Also -> Amazon link
jpr0204
Post by jpr0204 »
Wow Matt,
Incense Sticks? That is an awesome idea! And, truly the (very) poor man's smoke machine. :lol:
I thought my 1 gallon empty milk jug and some clear rubber tubing was the poor man's way but I guess I was wrong...
- Joe
Current Vehicles:
...and to complicate things ..my cruise is now non-working with no MIL, ETC, nor ABS light/code present nor pending.
I will fix it since I use this car as my most comfortable long distance cruiser. Im still smarting from the DIY FAIL of not connecting the intercooler turbo hose and chasing that for three weeks. :roll:
Colorado and Washington now providing some legal alternative smoke sources for vacuum testing, btw.
On edit - I did find an excellent write up of the 02 sensor operation in the Volvo 850 DIY archives above
