Help with misfire code
rjaywhit
Year and Model: 850 NA, 1995
Re: Help with misfire code
Post by rjaywhit »
Replace cap, rotor, and leads.
rjaywhit
Post by rjaywhit »
How do you test the coil? I noticed that it is ticking, is that normal.
Any recommendations for spark plugs for this vehicle?
Thanks.
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
Bosch super copper plugs. Autozone sells them. Gap to .03".
Look under the hood with the car running at night. If you see any blue arcing around the coil, which I suspect might be the noise you're hearing, the ignition coil is bad.
'98 S70 T5
2016 Chevy Cruze Premier
rjaywhit
Post by rjaywhit »
I don't see any arcing. I hate to spend the money on a new coil if it's not the problem.
jblackburn
A (truly) bad coil would be causing misfiring on more than one cylinder.
I would start with the swapping the injectors and put some new plugs in there to start diagnosing things.
'98 S70 T5
rjaywhit
Post by rjaywhit »
Yeah, When I pulled the spark plugs - 1, 3, and 5 were all normal and 2 and 4 were carboned up. So the coil must be ok if 1,3, and 5 are getting good spark. 2 and 4 are at the bottom of the dist cap and I saw a lot of carbon dust around those contacts.
I just thought of something that might be causing the rough idle and running -
Two Saturdays ago I removed the screen from the flame trap. It was cold that morning and I had to pull the MAF cable hard to remove it from the air cleaner housing.
The next day, Sunday, was when the rough running started.
Should I put the screen back in?
How can I check the MAF cable for any shorts?
jblackburn
Leave the screen out. It has no purpose except to clog up.
Do you have codes for the MAF sensor? A2 and A6? It won't cause misfires on just 2 cylinders, though.
http://www.volvospeed.com/CheckEngine.php
You said you replaced the cap and rotor, right? If the plugs are carboned up, change them as well. Too much gas and no ignition can foul a spark plug.
'98 S70 T5
rjaywhit
Post by rjaywhit »
So far I've replaced the plugs, leads, cap, and rotor. Still getting cyl 4 misfire codes.
The plugs are Motorcraft Copper - Autozone did not have Champion or Bosch copper.
I have only read codes on A2, I'll see what comes up on A6
jblackburn
Chances are if that plug was all carboned up, so is that cylinder. One of the valves may be sticking slightly and not allowing full compression in that cylinder.
2 things I would try (after a compression test to confirm my theory):
1) Drive the snot out of it at high RPM for 10-15 minutes to try to unstick the valve.
2) Seafoam treatment into the intake manifold. It really helps dissolve crap in the cylinders.
'98 S70 T5
kiss4afrog
Year and Model: 850 1995
Been thanked: 2 times
Post by kiss4afrog »
Second the Seafoam treatment.
You can never have too big a Turbo !
