1995 850NA 130K - A week ago my daughter got of the freeway and the car started running rough. I ran codes and found misc misfire codes for cyl 2 & 4. I replaced the cap and rotor since I knew that they were pitted and the plugs only had 15K on them. Still getting misfire codes. Replaced the plug wires and spark plugs. Now getting codes on cyl # 4 only. Running a little better, but still slow off the start and not idleing as it should.
I have found that the CEL is burned out so who knows how long she was driving with the issue.
How does the ECU know that there is a misfire? Since this is a distributor setup is there any management of the ignition by the ECU? If so, how?
Any ideas on what I should try next? Current codes are 5-4-3 , 4-5-4, 5-4-5, 5-5-4.
Could a damaged cat or fouled O2 sensors be causing a misfire?
Help with misfire code
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
I doubt that. The only thing you have left in the path is the coil and the injector. Do you run fuel injector cleaner in the car? I usually use Lucas no less than every 10,000. Make sure you have good gap on the plugs. I also think the MAF can cause rough running. Does your car have the OBD-II port at the coin holder?
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 19 times
Pull the plug out and ground it against the head while the engine's running. IS it firing?
If so, might be time for a compression test to see if it's got a burned valve.
'98 S70 T5
2016 Chevy Cruze Premier
tjts1
- Year and Model: 96 855 NA 5 speed
- Been thanked: 4 times
I would try different plugs. Either Volvo or NGK coppers.rjaywhit wrote:Autozone didn't have 5 Champion copper plugs in stock so I got Motorcraft copper plugs.
I'm hoping that I don't have a burned valve, I just rebuilt the head 15K ago. That would really suck.
Ambitious but rubbish
- Has thanked: 292 times
- Been thanked: 765 times
You can test the injector by swapping it to another cylinder, see if the misfire follows it.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
- rspi
Contact rspi..
People, please use OEM plugs or something believed to be better. I installed some champ plugs in one of my cars and the MPG dropped the same day about 20%. Only took my anal behind a week to realize it because I was driving about 1,000 miles per week. Took those things out and tossed them in the trash.
If you just rebuilt a head I doubt you have a burnt valve. I have heard in the past that running 87 octane will cause valves to burn a lot faster than 91+. I would swap the plugs and a fuel injector and see what happens.
jblackburn
I've never used Volvo plugs because of the ridiculous price, but NGK and Bosch Copper plugs have worked well for me. Just have to change them more often, but at $1.25/plug, who cares?
'98 S70 T5
boosted5cyl
- Year and Model: '98 V70 T5, '99 S80
You mentioned cap & rotor being replaced, what about the spark leads?
Most commonly misfires are detected by the ECU using the crank position sensor. It can sense very small variations in the motor's rhythm and point to the offending cylinder. If you get a chance to see the wheel for the crank position sensor you will see it has a lt of teeth, its very granular.
I've have read on forums that knock sensors are involved too, but my understanding of their operation does not indicate this. They are basically piezoelectric microphones that are "tuned" to listen for knocking in the motor and they only send a signal if knocking conditions are met. Otherwise they send no signal at all which means they cannot be involved in misfire detection. That's my take on it anyway.
O2 sensor and or clogged cat can cause poor running, but it would be more uniform(ish) across the cylinders. They are unlikely to cause an issue in just one specific cylinder.
'04 XC90 2.5T AWD (Angus) 134K.
'99 S80 T6 (Medusa) 214k. On borrowed time LOL
'98 V70 T5 (Vivienne). RIP @ 228K. Spun rod bearings.
