This chick wanted a nice car and.... Well read more...
Everything on the Volvo S80. Sometimes called an "executive car", the S80 was Volvo's top-of-the-line passenger car. P2 platform.
xHeart
Year and Model: 2.0/3.2
Has thanked: 113 times
Been thanked: 116 times
Re: This chick wanted a nice car and.... Well read more...
Post by xHeart »
There is a detailed discussion on ETM. See it under Home > Volvo ETM Page. https://www.matthewsvolvosite.com/volvos ... ule-fiasco
dcarlson12
Year and Model: 1997 850 T5
Been thanked: 2 times
Post by dcarlson12 »
Here are a couple of topics from VADIS regarding Limp home mode. VADIS is the equivalent of a factory service manual. It covers many years and models of Volvos including yours. It is on a CD which you can usually purchase for a few dollars on ebay.
2000 S80 Limp home mode 1.pdf
(37.16 KiB) Downloaded 453 times
2000 S80 Limp home mode 2.pdf
(651.22 KiB) Downloaded 319 times
chipmunkbug
Year and Model: 2000 s80
Post by chipmunkbug »
Thanks dcarlson12. That is exactly what I wanted. I am calling the transmission place to see what they have to say about the car.
Finger crossed.
chipmunkbug
And the transmission shop is treating me like I am dumb. They said two days ago they would have the diagnosis ready for me. Two days later, they still haven't done anything with it. Wow... Will post results whenever they get their act together.
adki110
Year and Model: XC90 2006
Post by adki110 »
Are you near Macon?
adki110
Post by adki110 »
Oops hit submit before I was finnished. If you are near Macon, Jackson Automotive on Riverside Ave worked with me when I was on a limited budget. Just an opinion, I would sort out the battery problem first, low voltage causes a host of problems in these cars. And if you now have a bad feeling about the shop, I would get it out of there. Good luck
chipmunkbug
Quick update, the transmission shop says it is definitely the solenoid but they don't have any way of checking it to make sure without taking the tranny out. Yay. They want $2200 for a rebuild. I found someone who is cheaper. I've read somewhere that rebuilds are probably junk too. Is this true? Ugh, I just want my damn car on the road with me in the driver seat.
bronxnativ
Year and Model: 96 850 GLT 5 Speed
Post by bronxnativ »
PM "jblackburn". He is a moderator here. I believe he has been through the solenoid issue with his tranny in the past. I'm sure he can tell you how to check the solenoid without removing the tranny.
Al
fazool
Year and Model: S60, 2007
Been thanked: 7 times
Post by fazool »
2007 S60 2.5T AWD (Daily Driver)
2001 S60 2.4T (Daughter's Car)
2003 S80 2.9 (Son's Car)
1995 850 2.4 (Daughter's Car - sold off)
2005 S40 2.4i (Bought new - since sold)
1986 740GLE 2.3(First Volvo - sold off)
dcarlson12
Here is a guy who specializes in the transmission used in your car. You may wish to try to wade through his site. He has a lot of information and it would arm you with good information when going to a transmission shop.
You could even print out what he does/recommends for the Volvo S80 version of the transmission and take it along to any shop who you might consider asking to do the rebuild for you. Ask the shop what they would do to 'harden up' the transmission.
http://www.tripleedgeperformance.com/
PS Edit: I don't believe it is necessary to remove the transmission to replace/check/access the solenoids, but it is still a lot of work to get to and remove the valve cover where the solenoids are located. If one is to replace the solenoids and I say solenoids (plural), then it one might as well go all the way and replace any worn or suspect parts at the same time. If you don't go all the way, then replace all the solenoids at least.
Let us know how you make out. :)
