But in this case you aren't trying to suck heat out of the bumper or any other area, you are trying to prevent heat from ever reaching the paint. The metal plate would clearly fail as a heat sink anyway, there is so little contact with the much larger and heavier metal pieces of the car. If anything, the car will work as a heat sink for the little piece of metal. You said the metal was getting too hot to hold in a gloved hand - then you are just making a big, hot piece of metal and holding it near painted surfaces, yikes!fazool wrote:Actually I wanted something thin and something that dissipates heat over a large surface area. its like clipping an alligator clip as a heat sink when you are soldering so excess heat goes in to the metal then radiates away.
Something that blocks hot air flow and doesn't get hot (either by quickly dissipating or by insulating) would be ideal. Aluminum foil does sound like a simple, easy-to-use and far more effective solution.
Don't get me wrong I don't mean to criticize - overall I think this looks like a clever and useful idea.
