Two things can make for low compression test readings on that car: Throttle must be opened and the variable valve timing cam positioning is not at optimal position during starter operation and will make for less than ideal readings. Cylinder leakdown is the now recommended method by Volvo.
Whoever does the repair will need a cam holding tool and will need to set the intake cam VVT unit properly.
Also they need to understand the mark on crank pulley is not at TDC so they should not be bothered by that.
Head gasket & timing belt relacement 2002 S60 non-turbo
Head Gasket Change Parts List
precopster
- Year and Model: Lots
- Been thanked: 128 times
Would be nice to hear back from the original poster to see how they went.
Did you have the car repaired and what cost did it eventually arrive at?
- 38 Replies
- 16143 Views
- 20 Replies
- 17600 Views
Last post by Hurtfeelings
- 18 Replies
- 6258 Views
- 517 Views
Last post by erikv11
- 12 Replies
- 2163 Views
Last post by oragex
