I believe that if there is a vacuum leak the engine will run lean and the combustion will be hotter too
Sent from my MB865 using Tapatalk
97 850 has high NO fail CA smog by 100 over max
volvobaggen
- Year and Model: 850 -1997 B5252s LPG
Im just airing my thoughts. When I had my 1977 245 wagon through emission testing, it failed miserably. I pulled out the air filter, filled the tank with 50% ethanol. The emissions were almost not detectable.
Ethanol burns cooler and should therefore also be able to decrease NO levels.
I know this doesnt fix the underlying issue, but could be worth a try.
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
Glad to know you are close to them. Use to watch IMSA GTP racing so I know of them. Hope they can be helpful!sinclair wrote:any idea where the charcoal canistar is located on my 850?
btw thanks, that shop is the next city over. I'll try them monday.
As for the Charcoal Canister please see link as I have not looked for mine yet.
http://volvoforums.com/forum/volvo-c70- ... ter-10777/
- MoVolvos
This guy failed 5 times so there is excellent information on the items to look at. The Fuel Pressure Regulator is one of them besides Fuel Filter and the Injectors.sinclair wrote:i just discovered a hiss coming from the fuel pressure regulator. woul that have anything to do with this problem?
http://www.yotatech.com/f116/help-high- ... if-222662/
I just want to confirm what part this is. It looks to be a fuel pressure reguator, it's just down stream of the fuel filter attached to the fuel line, it has a sepperate line going to the gas tank and a vac line that is attached to a line going to the charcoal filter.
- MoVolvos
It lists 3sinclair wrote:I just want to confirm what part this is. It looks to be a fuel pressure reguator, it's just down stream of the fuel filter attached to the fuel line, it has a sepperate line going to the gas tank and a vac line that is attached to a line going to the charcoal filter.
http://www.eeuroparts.com/Main/PartsRes ... egory=1020&
& it looks like this one
http://www.eeuroparts.com/Main/PartDeta ... id=9146761
I have this one on my 98 S70 T5 Fuel Injector Rail and is it listed under 97 850 also. Not sure how many are on each car or between production years or engine numbers?
http://www.eeuroparts.com/Main/PartDeta ... id=1275658
Hope this helps?
Matty Moo
- Year and Model: 850, 1996
- Has thanked: 1 time
- Been thanked: 30 times
This guy knows what's up, and it works. Google it, lots of people do it.volvobaggen wrote:Im just airing my thoughts. When I had my 1977 245 wagon through emission testing, it failed miserably. I pulled out the air filter, filled the tank with 50% ethanol. The emissions were almost not detectable.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
- MoVolvos
Hi Matty Moo,Matty Moo wrote:This guy knows what's up, and it works. Google it, lots of people do it.volvobaggen wrote:Im just airing my thoughts. When I had my 1977 245 wagon through emission testing, it failed miserably. I pulled out the air filter, filled the tank with 50% ethanol. The emissions were almost not detectable.
I did not want to send that post as I think you can potentially get in serious trouble for that in CA!
- 2055 Views
Last post by Dmck
- 5745 Views
Last post by Flybrk
- 589 Views
- 3686 Views
Last post by RickHaleParker
- 781 Views
Last post by 93Regina
